7.3 EBP Reading - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-05-2013, 04:08 PM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
7.3 EBP Reading
This is more for the tuning guys, but whoever knows, idc.
What does the EBP do to fueling?
And does the PCM have a default value for the EBP sensor if you unplug it?
Reason I ask, my tube is clogged as effh, and just barely cracked. I'm sure it's been like that forever, so not like it really matters.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #2 of 13 Old 05-05-2013, 10:06 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Your fuel economy will bite the dust, i dont know EXACTLY what it does to fueling but basically it uses that tube/sensor to read the backpressure and based on that it fuels or defuels. with a clogged/unplugged sensor the engine thinks theres no backpressure so it injects excess fuel into the engine to try to up the BP thereby basically wasting fuel. Someone more knowledgeable can chime in but thats my understanding.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 13 Old 05-05-2013, 10:10 PM
That sure makes since but wouldnt you start to see black smoke with the excess fuel as a sysmtom of clogging?
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #4 of 13 Old 05-05-2013, 10:13 PM
Chapter Director
Quoted: 5 Post(s)
Well the extra it adds is probably very minute at most so maybe its just mistaken for a lead foot but enough to tank your mpgs
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 13 Old 05-05-2013, 10:18 PM
Ok, who knows. One things for sure you have to love a diesel to own one.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #6 of 13 Old 05-05-2013, 10:25 PM
Chapter Director
Quoted: 5 Post(s)
You can say that again on another note i see you still have the paddle mirrors on ur rig, you interested in my tow mirrors im puttin a set of 08s on it this week hopefully if i get it back from the shop. They only have a small crack on the drivers housing and the black is rubbed off a bit where it slides in and out.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 13 Old 05-05-2013, 10:27 PM
I had never though of changing them. I look em up and see. What ya want for them and where are ya.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #8 of 13 Old 05-05-2013, 10:28 PM
Chapter Director
Quoted: 5 Post(s)
sending PM so we dont muck up the OPs post
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 13 Old 05-06-2013, 08:15 AM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
idc you keep bumping it up
I left it unplugged and the sensor off in hopes it'd blow the tube out
I was wondering if it's like the ICP sensor being unplugged. The PCM just inputs a default value for the missing data so it can run. It seemed to run fine, but just maybe a little different. Idk, hard to tell.
My mileage is around 15.5 with tube clogged and tiny hole/crack.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 13 Old 05-06-2013, 08:38 AM
Chapter Director
Quoted: 5 Post(s)
true
But yea i mean depending on what lift/tires/mods you have thats a pretty average mpg but from what i have read its alot better to have plugged in and working correctly. A new tube is like 50 bucks so you can go that route if you want or just clean it and repair the crack. The sensor is the part that is outragous. its like 200ish for a damn sensor but at least yours works
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
