Turbo replacement issue - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-05-2013, 09:48 AM Thread Starter
I just received a new (remanu) gtp38 and pedestal for my 2000 7.3 (stock). When comparing the old turbo & pedestal side by side to the new ones, I noticed that the new pedestal doesn't have the EBPV solenoid connector. The new turbo also doesn't have the EBPV actuator. If i install this new combo, what do i do with the EBPV connector, just leave it hanging?
hemloc is offline
post #2 of 8 Old 05-05-2013, 10:50 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Leave it hanging. I'd love to get the non EBPV outlet/pedestal.
Dfuser does have a resistor that plugs into the harness to eliminate the soft code but it's worthless to me.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 05-05-2013, 11:25 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
ya i want to get the same kit.
the turbo you got basically has a non ebpv pedestal so you wont get any leaks from that and it sounds like a high flow outlet so no butterfly valve.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 8 Old 05-05-2013, 12:01 PM Thread Starter
Ok, I guess I will leave it hanging then. Thanks for response guys.
hemloc is offline
post #5 of 8 Old 05-06-2013, 07:48 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yep you have the pedestal most guys swap over too because it gets rid of the EBPV so when its cold you wont have the annoying cutout of power when you go over 2000 rpms
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 8 Old 05-06-2013, 09:49 AM Thread Starter
Ok, I got the new turbo & pedestal installed now and took it for a spin; sounds & feels much better, BUT.. now i have an oil leak. Not happy. I can't see exactly where its coming from but i'm guessing between pedestal and turbo..? Anyone experience this? Its leaking profusely mostly after i shut it off. I did put in both those 2 little O-rings, but there's nothing else between turbo & pedestal, which didn't seem right at the time. Before i start over, anyone have some good advice for someone who knows little about what he's doing?
hemloc is offline
post #7 of 8 Old 05-06-2013, 12:46 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Should be four orings. Two between turbo and pedestal. Two between motor and pedestal.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 8 Old 05-06-2013, 12:56 PM Thread Starter
Thats what i thought! BUT, both surfaces - between motor & pedestal - it was completely flat, even next to both ports. There isn't any grooves for the o-rings to seat into.
hemloc is offline
