  #11 (permalink)
Old 02-27-2008, 03:49 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
I like using a bench vise. I like to remove the driveshaft and press the u-joint out in the bench vise. Also if your replacing one you might as well replace both U-joints. There is one on each end. For the cost it is worth it.
Just remove the driveshaft and replace both u-joints and then put the driveshaft in. If your concerned about pressing out the u-joint yourself. I am sure a local machine shop will do it for you for a small fee. Or even a local mechanic shop.
  #12 (permalink)
Old 02-27-2008, 04:00 AM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
so which one BC?? a local machine shop or a local machine shop!!! LMAO!!
  #13 (permalink)
Old 02-27-2008, 04:04 AM
Either one would do it for a small fee I am sure of it. I don't know where he lives, I don't know if there is a machine shop in his town. There for I made that statement.
  #14 (permalink)
Old 02-27-2008, 04:05 AM
Rob Rob is offline
Free Faller
i see that bud, but you mentioned a local machine shop twice like its 2 different places!! just messin with ya!!
  #15 (permalink)
Old 02-27-2008, 04:08 AM
In 3 hours I would be up for 24 hours straight. Give me a break man.
  #16 (permalink)
Old 02-27-2008, 04:09 AM
Rob Rob is offline
Free Faller
holy crap, get some sleep!!!!
  #17 (permalink)
Old 02-27-2008, 06:23 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
Be careful if you decide to change the front joints in the rear shaft. Mine has a double U-joint in the front and there is also a ball and socket with lots of tiny little needle bearings that will go everywhere when you take it apart. I bought new U-joints with no problem but could not find anywhere that sold the ball and socket bearing. The Ford place said you had to replace the whole drive shaft. I went home and spent hours trying to find all the old needles and clean them and put it all back together. That was about 3 years ago so it worked good but was a real pain.
  #18 (permalink)
Old 02-27-2008, 07:41 PM
shadowe123 shadowe123 is offline
well i changed the front one today and it still does it so im gonna try the one right behind the tranny next... thats the last one....whats that thing called that makes the drive shaft slide back and forth???could it be that???
