dp tuner problem - Ford Powerstroke Diesel Forum
Old 02-23-2008, 11:44 PM
dp tuner problem
i installed a dp tuner last night and it ran great. then today it ran good till i used the econo mode and then the check engine light came on. while driving on econo it would all of a sudden just cut out for a split second every once and a while. it doesnt do it when i drive around on 140 smoke setting. i had it checked by 3 different scan tools and none of them came up with anything. they said it had connected with the computer but no codes.
Old 02-23-2008, 11:50 PM
did you get a boost fooler
Old 02-23-2008, 11:52 PM
Send a message via AIM to 06Blackmamba Send a message via Yahoo to 06Blackmamba
is it retarding the timing to much it? my hypermax does that on same mod and called them they said it retards the timing to much for your elevation, and even then when i was in texas it did it just retarding the timeing to much and not allowing it to fire right.
Old 02-23-2008, 11:53 PM
yes, and i was just driving like 60 mph for about 10 minutes and when i came to stop the check engine light came on and the truck just died
Old 02-23-2008, 11:56 PM
hmmmmmmmmmmmmmmmm
Old 02-23-2008, 11:57 PM
i dont know if its retarding too much. hey scheidt27 where around minneapolis are you at?
Old 02-24-2008, 12:02 AM
another way to find out is hook a laptop up to it and drive it and find out whats going on if its retarding or trying to keep the injector open to long and over fuel it at lower rpm. Does it smoke alot when idiing with it on that econo?
Old 02-24-2008, 12:05 AM
i havnt really let it idle on that, but it does idile a little rough and 200 rpms lower then stock
Old 02-24-2008, 12:08 AM
mine was doing the same thing and it was timing problem, they retarded the hell out of it to make it get better mpg and when my truck is on that mod it smokes like hell and stinks omg drove me nuts i just left it on the next stage and worked fine. let me know if you notice anything else
Old 02-24-2008, 12:12 AM
yeah i emailed itp diesel and dp-tuner. hopefully they will have an idea. i just wish i could get a code to read so i have some idea
