1st MOD! and 2 questions... - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-23-2008, 10:52 PM Thread Starter
Smile 1st MOD! and 2 questions...
We got our tax return back from Uncle Sam so I celebrated my doing the DIY mod today!
Got a 3" piece of 4" exhaust pipe, the guy at the muffler shop cut it for me and just gave it to me at no charge after I told him what I was going to do. Got the filter at NAPA for about $45.00.
It took about 45 minutes. I de-burred the pipe then scrubbed it with steel wool and washed it real good to get rid of any metal pieces, then I took off the air tube and cleaned out in front of the turbo, there was some old oil cruded up in there, not much but I figured I may as well clean it out.
Took the Beast for a quick drive, more turbo sound, can hear it winding up a bit more and can also hear something change when the RPMs change with shifting, must be the blades spinning?
Sounds good, drove great, can't wait to try it on a longer drive tomorrow.
Pretty easy mod, really.
Questions - whats the tube that comes up in front of the turbo inside the airway and the should I put sometihng under the filter to keep it from getting crud thrown up on it? Seems that it's pretty open to the road in there now.
Thanks Maintain's GREAT!! photos and write up on this!
99 F350 Crew Cab Long Box 4X4
234 k and counting!!
PHP Phoenix - 5 positions
Banks Bighead Wastegate
Banks 4" exhaust
DIY NAPA Intake Mod
HPX Crossover line
Marinco Mod
MtPaul401 is offline
post #2 of 14 Old 02-23-2008, 11:11 PM
International Threat
Marty's Avatar
No problem!
That tube that sticks up in the intake is the CCV. A lot of people plug that hole or replace that hard plastic piece with an exhaust pipe and then route the CCV elsewhere... usually to a catch can or to the atmophere. Make sure you get heater hose and if you route it to the atmosphere you route it as far back as possible to avoid the fumes, cus they stink!
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 14 Old 02-23-2008, 11:11 PM
Marty's Avatar
btw where are you from?
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #4 of 14 Old 02-24-2008, 09:07 AM Thread Starter
Is there an advantage to re-routing the CCV?
I'm in western Montana, Missoula area.
Thanks!
Banks 4" exhaust
DIY NAPA Intake Mod
HPX Crossover line
Marinco Mod
post #5 of 14 Old 02-24-2008, 09:46 AM
Other vehicle is an F250
Hank's Avatar
You'll like the DIY Intake. I did mine a couple of weeks ago. I have an auto tranny but the sound, I've been told, between your shifts and when you get off of the pedal, I bet, is the excess air that is on its way to the turbo and now must exit somewhere. So best I can tell, it comes back out of the filter. No one has ever mentioned it, but I guess the sucker is self cleaning.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #6 of 14 Old 02-24-2008, 10:03 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
either that or hes hearing the excess boost going out the wastegate. CCV mod is easy to do. It will keep all that oil and gunk from getting through your intake tract, and more importanly, in to your engine!
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 14 Old 02-24-2008, 10:39 AM
Marty's Avatar
CCV mod just reroutes the CCV from your intake tube to elsewhere.
Keeps the oil out of the intercooler...
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #8 of 14 Old 02-24-2008, 11:44 AM
ksttac's Avatar
where do you route it to keep oil off the driveway?
2001
F350 CC LB SW 4X4
7.3 Powerstroke, Auto
Eagle Wheels
Nitto Terra Grapplers
Ranch Hand Rear Bumper
Tietjens Brush Gaurd
04 Headlights
HPX Line
Magnaflow 4" SS Turbo Back
Pro Comp leveling kit
Amsoil front to back
"Hurdle the Dead, Trample the Wounded"
ksttac is offline
post #9 of 14 Old 02-24-2008, 11:51 AM
Marty's Avatar
A filter or catch can that you can change/empty periodically.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #10 of 14 Old 02-24-2008, 11:53 AM
ksttac's Avatar
any ideas on what kind of filter........and i know ive seen it but where is the instructions on here for the mod, and is there a filter kit you can buy
2001
F350 CC LB SW 4X4
Eagle Wheels
04 Headlights
HPX Line
ksttac is offline
