Help with bent bracket - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2013, 04:45 AM Thread Starter
I replaced my exhaust back pressure sensor and accident bent the bracket out screws into. I bent it back and everything lined up fine. But I thought I noticed some sort of sealant behind the bracket plate.
Do I need to worry about breaking the seal behind this bracket and having problems, or is the bracket just bolted on with nothing behind it?
E99 F250 Super Duty
MonRiver is offline
post #2 of 4 Old 05-03-2013, 06:35 AM
timmyboy76's Avatar
not sure about sealant, but i had to finnesse the bracket as well, to align the tube/sensor
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 05-03-2013, 12:58 PM
JSchuricht's Avatar
Make sure you didn't bend the tube any, it's easy to break it if it has been on the truck for a while. The plate that the bracket is on is for the HPOP gear inspection/bolt, there is RTV on it but it's not pressurized and just gets oil splashed against it. I pulled mine several times without replacing the RTV and never had a leak. If you want to upgrade, Strictly Diesel has a cover that uses a oring and a new tube that reroutes the sensor away from the cover.
JSchuricht is offline
post #4 of 4 Old 05-03-2013, 01:35 PM Thread Starter
Great!
I bent it before i put the new tube on, so the tube is fine. The old tube, well it was in two pieces when I took it off!
E99 F250 Super Duty
MonRiver is offline
