ccv mod/o-rings part# - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-23-2008, 05:25 PM Thread Starter
scheidt27's Avatar
Anybody know the part number for the 2 o-rings under the doghouse. I was doing my ccv mod tonite and they were bad so I have to finish it tomorrow after i get some more o-rings. If anyone knows the napa/checker part number that would be awesome too, thats were i will be going since ford is closed. thanks
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #2 of 16 Old 02-23-2008, 05:28 PM
International Threat
Marty's Avatar
Not real sure what o rings you're talking about? And I've done several CCV mods...
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 16 Old 02-23-2008, 06:33 PM
99bigred's Avatar
i lost one of mine and just took the whole thing with me to kragen and found the best fitting one, if i go out to the garage ill see if i see the bag they came in for the part number.
early 99 f-350 7.3 6speed crew cab
banks exhaust, chip, big head, exhaust houseing
and wheel
Ford AIS intake
5.5" fabtech lift w/ 35x12.50/18's
99bigred is offline
post #4 of 16 Old 02-23-2008, 06:36 PM
tubular031's Avatar
i got em here
Replacement O-rings for Diesel Engines
along with a few other ones (turbo, HPOP and CPS)
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #5 of 16 Old 02-23-2008, 07:20 PM
I just did mine yesterday. Had the same problem. Ford said they are glued to the unit and you have to buy the unit. I thought that was BS but anyway I found two bigger orings, cut then to fit, glued the ends toghther and to my suprise it worked. Didn`t know about this site though.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
post #6 of 16 Old 02-23-2008, 08:09 PM Thread Starter
scheidt27's Avatar
There the ones underneath the doghouse. There are 2 holes in between the doghouse and the valve cover. The 2 o-rings that are for those 2 holes, they are beveled if that helps.
2002 F250
All Supporting Mods
post #7 of 16 Old 02-23-2008, 08:13 PM
Tubular 031 just posted a link for you. They have them $3.50 Cheap enough. The bevil goes upward I believe.
Triflex is offline
post #8 of 16 Old 02-23-2008, 08:19 PM
todd's Avatar
yep dieselorings.com thats where i get all my rings cheap and fast shipping and they get you the viton ones order from there drive on the bad ones till the new ones show up ive made 3 orders from them all 3 were here in 2 days your gettin regular rubber ones at napa
traded it for an 06 dodge sorry
todd is offline
post #9 of 16 Old 02-23-2008, 08:20 PM
todd's Avatar
heck order all the prone to failer ones while your at it to so youll have em on hand thats what i did on my last order
todd is offline
post #10 of 16 Old 02-23-2008, 08:36 PM
Marty's Avatar
Are you guys talking about the actual ccv which has the L shaped heater hose coming out of it?
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
