4x4 Issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-02-2013, 03:32 PM Thread Starter
jdereu's Avatar
4x4 Issue
My issue is the the 4x4 switch on the dash isnt engaging the four wheel drive. I cant hear the transfer case go into 4 Low from 4 High not so much from 2WD to 4 High. The light on the dash is coming on. If i have it in 4 High get out and lock the hubs it works. Anyone have any ideas?
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 3 Old 05-02-2013, 04:13 PM
goats's Avatar
Quoted: 2 Post(s)
Your hubs are not engaging. meaning they are leaking vacuum from the hubs them self or the vac line going down to them is leaking. Vacuum is what makes them work or you can turn them by hand.
goats is offline
post #3 of 3 Old 05-02-2013, 04:40 PM Thread Starter
jdereu's Avatar
replaced the lines going to the spindle from the frame they were history but that little switch thing on the pass fender well has vacuum going to it but none coming out is that thing shot?
jdereu is offline
