2000, 7.3 Powerstroke wont start. - Ford Powerstroke Diesel Forum
Old 02-23-2008, 10:51 AM
My 7.3 wont start, started running rough then died, changed the fuel filter and camshaft position switch ( recall letter ) and it will crank and sound like it is trying to start but wont, plugged in the block heater to help warm it up, but no luck. Any sudjestions?
Old 02-23-2008, 04:01 PM
depending on temperature your fuel may have gelled. Any codes?
Old 02-23-2008, 04:32 PM
Thanks, No Codes that I can see. It only got to 38 deg. F not cold enough to jell. the fuel I drained to check was fine.
Old 02-23-2008, 05:06 PM
how bout checking the oil in the HPOP?
Old 02-23-2008, 05:10 PM
ADMIN AND TECH
not sure but sounds like a fuel pressure problem, if it sounds like it wants to crank , its probably fuel pressure
Old 02-23-2008, 10:10 PM
Mine did the exact same thing, I tried everything.. It turned out to be the glow plug relay. It is super easy to replace and once I did she fired up like a champ~!
WFI
Old 02-24-2008, 01:59 PM
ADMIN AND TECH
WFI
his first post he said it shut off going down the road , glow plug relay will not shut the engine off driving
