Pulled axle shaft and seen this - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-02-2013, 12:02 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Pulled axle shaft and seen this-imageuploadedbyautoguide1367524883.292869.jpg
This is the passenger side the driver side looked fine. Is this a problem? What would've caused this?
Sent from AutoGuide.com App
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #2 of 14 Old 05-02-2013, 12:06 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
you talking about the groove on the Yoke?
2000-7.3L is offline
post #3 of 14 Old 05-02-2013, 12:11 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Groove and rust on the shaft
bck4more is offline
post #4 of 14 Old 05-02-2013, 12:21 PM
2000-7.3L's Avatar
bad inner seal?
post #5 of 14 Old 05-02-2013, 12:42 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Well I'm in middle of replacing seals, ball joints and tie rods
bck4more is offline
post #6 of 14 Old 05-02-2013, 12:43 PM
2000-7.3L's Avatar
Looks like a bad inner seal that made it do that!
post #7 of 14 Old 05-02-2013, 12:44 PM Thread Starter
LEARNING AS I GO
bck4more's Avatar
Should I sand the shaft down to remove the rust off of it before putting it back in? Also in the spindle where the axel shaft seal sets there's a even lip all the way around should that be there or should the inside of spindle be smooth
bck4more is offline
post #8 of 14 Old 05-02-2013, 12:45 PM
2000-7.3L's Avatar
yes sand that rust down! could even put a little never seize on there after its all cleaned up
post #9 of 14 Old 05-02-2013, 02:46 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
the rust is from the dust seal failing and letting stuff get in there.
mine looked the exact same.
not a huge deal. most trucks dont even have dust seals.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #10 of 14 Old 05-02-2013, 02:52 PM
ZMANN's Avatar
Quoted: 1891 Post(s)
Agreed that has nothing to do with the inner axle seal
that failure would let oil run out of the diff
the outer dust seal is more like a rock blocker and doesn't prevent water intrusion down the tube later they improved the seal and it now goes in the axle tube end vs the shaft
they can be retrofitted but there is a cutoff date where they won't fit older axles and I don't recal the year
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
