Groan in reverse - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-02-2013, 01:07 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Groan in reverse
This started a few weeks ago but has been getting worse. Is it common for the brakes on these trucks to groan or am I looking at a problem?
I have 2 guesses... either I have a bad caliper or the E-brake shoes have fallen apart.
Sound about right or is there some other common cause?
schlutzer is offline
post #2 of 3 Old 05-02-2013, 04:38 PM
ScottyP5947's Avatar
Quoted: 2 Post(s)
I'd say you have an issue, check your caliper slide pins and check for stuck calipers. Seem to be a common issue on these trucks to find seized pins or calipers or both. Easy fix either way, you can get pin kits to replace the pins and boots.
Good luck -
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #3 of 3 Old 05-07-2013, 02:28 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Posting the solution as its a huge pet peeve of mine when your googling a problem and you know damn well the person found the answer but never posted back.
My top slider pin was stuck. About an hour to wrestle it out.
Check that pad wear, seems its been like this a while.
Interestingly enough, the bottom slider was moving freely, but looks like crap, all rusted. The top one which was siezed, was still nice and shiny. For now I clean out the hole and put some synthetic brake grease till payday. It's moving great again.
