Tranny cooler question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-01-2013, 04:44 PM Thread Starter
jdereu's Avatar
Well my tranny is getting 90-110 over ambient when I get stuck in traffic so the stock cooler is not working. It does have a rebuilt tranny in it if that matters. I found a cooler at a auto part store in town and was wondering if it will work (hope so cause I already bought it) my question is do I remove the stock one completely or do I run it inline? It says its rated for 10000 lbs ill post a picture of it when I get home
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 11 Old 05-01-2013, 06:20 PM
01Crewcab7.3's Avatar
My advice, for what it's worth...take it back and get a 6.0 cooler.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 11 Old 05-01-2013, 06:23 PM Thread Starter
jdereu's Avatar
I spent $60 on this one i really dont have the $250+ to spend on a 6.0 or try to find one
jdereu is offline
post #4 of 11 Old 05-01-2013, 06:27 PM
JSchuricht's Avatar
That's probably about the same size as the stock one. You need to check the size of fittings, if they are any smaller than stock don't run it. Otherwise, run it in series as the last cooler in the loop.
JSchuricht is offline
post #5 of 11 Old 05-01-2013, 06:29 PM
Have some experience with this, if you get a used 6.0 cooler your tranny guy will likely not cover your tranny anymore most will only cover it if its installed new. Just a word of caution.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #6 of 11 Old 05-01-2013, 06:33 PM Thread Starter
jdereu's Avatar
the fittings are 3/8". How do you tell which one is the feed and which one is the return going into the stock one?
jdereu is offline
post #7 of 11 Old 05-01-2013, 06:34 PM Thread Starter
jdereu's Avatar
more of a reason to run this one i guess haha
jdereu is offline
post #8 of 11 Old 05-01-2013, 06:49 PM
jesilvas's Avatar
Quoted: 2 Post(s)
10k lbs is a little more than your truck weighs. Waste of money.
tru cool max 47391 would be a decent upgrade.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 11 Old 05-01-2013, 08:06 PM Thread Starter
jdereu's Avatar
Think it won't work inline also?
jdereu is offline
post #10 of 11 Old 05-02-2013, 05:16 AM
hansel's Avatar
Quoted: 94 Post(s)
I know a 6.0L cooler is pricey, but it's a upgrade that is a MUST!!! if you are towing anything. My trans temp. hasn't gone over 150* and thats pulling my 8,000lb Keystone Laredo camper, the swap out is fairly easy, you need some 1/2" transmission line, the fittings to go from 3/8"-1/2" and about 2-3 hours too do the job. When you see the size of the 6.0L cooler is almost the same size as the a/c condensor thats how much larger it is compared too the stock cooler thats about the size of a computer keyboard.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
