r4100 tranny? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-30-2013, 10:02 AM Thread Starter
kentuckypowerstroke03's Avatar
r4100 tranny?
What is the normal operating temp for a r4100. Mine is running right at 180 when driven about 20 miles unloaded.
:flag
2003 F250 4x4 Super Duty 7.3L
4x4
95,000 miles
4R100
CTS gauges
6.0 Transmission cooler
Shift kit
K&N cold air intake
Straight pipes
PLENTY LEFT TO DO!!
kentuckypowerstroke03 is offline
post #2 of 9 Old 04-30-2013, 10:03 AM Thread Starter
Sorry I ment a 4r100
:flag
4x4
95,000 miles
4R100
CTS gauges
Shift kit
K&N cold air intake
Straight pipes
PLENTY LEFT TO DO!!
post #3 of 9 Old 04-30-2013, 10:12 AM
These transmissions operate pretty hot due to the factory cooler being too small for the application. Do a search on upgraded coolers, I installed one that was off the shelf at O'reilly Auto; dropped my temps 40-50 degrees even when towing. I don't like to see anything over 190 personally.
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #4 of 9 Old 04-30-2013, 10:19 AM Thread Starter
Well, I put an aftermarket cooler on mine made by torque flow. I left the old one in there and just put the new one in front of the condenser.
:flag
4x4
95,000 miles
4R100
CTS gauges
Shift kit
K&N cold air intake
Straight pipes
PLENTY LEFT TO DO!!
post #5 of 9 Old 04-30-2013, 10:26 AM
You may need to drop the pan and do a flush, filter, re-fill. I have my temp sensor in the inspection port at the pan and it doesn't get above 180 even when its 105 out and I am in stop-go traffic. Sounds to me like you might a restriction somewhere.
blderman is offline
post #6 of 9 Old 04-30-2013, 05:36 PM
AnthonyU's Avatar
Quoted: 8 Post(s)
Sounds like your tranny cooler could be restricted stop at a trans shop and they can tell you how much its flowing if its clogged and not flowing enough its a slow death for your trans. Don't just add another cooler and think thats going to help its probably your cooler.
AnthonyU is offline
post #7 of 9 Old 05-01-2013, 03:48 AM
180* is design operating temperature. Don't really need to worry until you start to go over 210*-220* with today's materials & fluids. Some of the "charts" floating around out there are from the 60's and obsolete. When you say you left the old one in do you mean in the loop or just sitting there? If they are both hooked up in series it may be too much restriction.
hydroman is offline
post #8 of 9 Old 05-01-2013, 05:03 AM
hansel's Avatar
Quoted: 95 Post(s)
Mine has not gotten over 150*, I have installed the 6.0L cooler and trashed the tiny little wimpy stock cooler
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #9 of 9 Old 05-01-2013, 05:57 AM
Which reminds me - whenn I am home I need to hit the salvage yard for another 6.0 Cooler, this time for MY truck. I've gotten 2 for my dad's and friend's trucks - before I owned an auto. But being that summer is coming, and my trans is only about a yr old I better get a bigger cooler on her soon.
2001 CCLB SRW 6spd - 375K and counting
2003 GMC Yukon - Her baby Hauler
1992 Acura NSX
1997 Honda Civic Hatchback - 2.4 liter, 6266 Turbo
ProOnThaSnow is offline
