Factory high idle - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-30-2013, 07:35 AM Thread Starter
Wyofordpower's Avatar
Quoted: 2 Post(s)
Factory high idle
Anyone played around with getting the factory high idle in a 6spd truck to work without having to apply the emergency brake? I like the high idle for letting the truck warm up when it's cold, but I really don't like using the emergency brake in the winter since the last thing I need on my way to school or work is a frozen on e-brake.
Obviously a chip with high idle would be ideal, but has anyone just modified the factory stuff?
Wyofordpower is offline
post #2 of 12 Old 04-30-2013, 08:24 AM
You could install a toggle switch to make the truck think it had the E-brake on.
01 F350 Dually 4x2 Long 7.3 - Manual - Mods: Hutch, Harpoon, Remote Fuel Filter, Southbend Clutch, Heim Joint, Gauges, Disabler, 08 Tail w/Camera, Pioneer Head w/Lockpick, Exhaust Brake, Rails, Air Raid, 06 Headlights, 50 cent. Coming next: Exhaust. Wish list: Train horn, 4x4 conversion, Exhaust, Turbo, Chip.
06 Mustang GT - GCC spec (Infidels May be closer than they appear)
13 Elantra - Gas saver
Arizona_SVO is offline
post #3 of 12 Old 04-30-2013, 10:54 AM
Quoted: 27 Post(s)
I believe this is the only way without getting a TS style chip.
You could even press the E-brake pedal down about an inch or 2 (it shoudl stay down), the brake light will come on without actually engaging the brake all the way. Might try that if you dont want a switch.
CarportMechanic is offline
post #4 of 12 Old 04-30-2013, 12:22 PM Thread Starter
Quoted: 2 Post(s)
How would you wire up a switch? Make it so that the switch sends power to the high idle fuse when you turn the switch on?
post #5 of 12 Old 04-30-2013, 12:58 PM
Quoted: 27 Post(s)
Basically a jumper wire in the little switch that gets pressed in when you release your brake.
Look under your dash where the little black rubber deely on your e-brake pedal pushes in a small black post. When your ebrake is released the rubber deely pushes the black post up disconnecting the circuit. Tap a wire into each wire going to the black post and put a switch between the 2 wires. Flipping on the switch will make the truck think you have pressed your break pedal in there-fore allowing it to go into high idle mode after 90 secconds.
post #6 of 12 Old 04-30-2013, 01:06 PM Thread Starter
Quoted: 2 Post(s)
I may have to try this for next winter. I'll play with it when I'm done with school in a few days.
Any adverse effects to leaving the switch on while driving around? So that the truck is warming up while sitting at lights an such?
post #7 of 12 Old 04-30-2013, 01:07 PM Thread Starter
Quoted: 2 Post(s)
Just realized that even with switch on the truck comes off high idle as soon as you touch the throttle.
post #8 of 12 Old 04-30-2013, 01:22 PM
Quoted: 27 Post(s)
Yes it does, but if you sit at a light or go to a coffee stand it will kick back into high idle mode after 90 seconds of no throttle I believe, dont quote me on that as im not 100% sure. But it sounds good! haha
So that would be an upside to the chips, would be in high idle mode whenever you stop but i have read its not good to drive with high idle mode on.......but this is something i just read, no real experience with this.
post #9 of 12 Old 04-30-2013, 01:24 PM
Your brake light on the dash would be on - but that's the only 'downside' I can think of off the top of my head. Sitting at lights would not get you anything because unless it was a long light, it would never kick into high-idle. Just use your foot to keep RPM's up.
post #10 of 12 Old 04-30-2013, 01:50 PM
Quoted: 27 Post(s)
A couple lights on my way to work are red for 5 minutes if you hit them at the rigth time, no joke. That is the only reason i said that. But also why i said 90 secconds, that how long it takes for the high idle to kick in once it realizes the E-brake is on. So if you aint at a light for more than 90 seconds it wont come on.
But another down side would be the annoying *** chime your truck makes when you leave your e-brake on and start to drive around. That would kill it for me.
