U-Joints andCarrier Bearing - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-29-2013, 05:35 PM Thread Starter
Silver200273L's Avatar
I'm having bad vibration around 40mph and thought it was my shocks but I think my carrier bearing is shot. There is play in it and want to replace carrier bearing and will do the u-joints while I'm at it. Now my question is how can I know which carrier bearing is right one for me? I looked around and most part store will have 2 different carrier bearing with different size. I know my truck is 172 wheelbase but I'm not sure which one is right one. Also what brand would you guys recommend? Will any of you buy O'Reilly's brand?
DP Tuner
Dieselsite Wicked Wheel II
5" Straight Pipe
6637 DIY Intake
Riffraff Intercooler Boots
Riffraff CCV
Harley Davidson Headlights Conversion
05-07 Grille
2.5 Leveling Kit
33" BFGoodrich All Terrain
LED tail lights
Billet Grille
Line of Fire
Silver200273L is offline
post #2 of 7 Old 04-29-2013, 06:28 PM
Gunner
GunnerB's Avatar
I got mine form rock auto. Went and dug a little. This is what I used to cross reference to find the correct part number. I used the Timken if I recall correctly, can't go wrong with those.
http://www2.dana.com/expertforms/dek350.aspx
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
post #3 of 7 Old 04-30-2013, 02:46 PM Thread Starter
Thanks! Would like to change them this weekend and I usually order parts on Rock Auto but don't think will get here by this weekend. Would you or anybody use O'Reillys? They have other brand name that they carry it called National. Any good? I was going to do it myself but in town where I live they do driveshaft and 4x4 trucks. I called them and ask for estimate. They gave me estimate for 3 U-Joints and carrier bearing and labor. All total will be $151. I don't think it that bad?
To correct about my previous post. My truck is 158 WB not 172. Also I know which carrier bearing I need. Will need the one that has 1.574 inch diameter for the driveshaft.
DP Tuner
5" Straight Pipe
6637 DIY Intake
Riffraff CCV
05-07 Grille
2.5 Leveling Kit
LED tail lights
Billet Grille
Line of Fire
post #4 of 7 Old 04-30-2013, 10:18 PM
Gunner
GunnerB's Avatar
Sorry, I totally misread your OP. I would go with a timken or national brand if I could, but in a pinch I would use just about anything from anywhere.
AIS Intake
4.5" ICON Lift
PHP Hydra
6.0L Cooler
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
DS Trans Cooler
Bilsteins
GunnerB is offline
post #5 of 7 Old 05-01-2013, 06:54 PM
Eco Taxi's Avatar
I got my carrier bearing from oriellys when mine went out a month or two ago. I think I used the bigger one but I bought both then just matched the salvageable ring size of the previous carrier bearing. My carrier bearing completely blew out so when I pulled e old one off I took the inner metal ring (I think) and placed it on top of the two new ones and it matched to only one. Lastly I just returned the non used one after the project
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #6 of 7 Old 05-01-2013, 08:43 PM
Quoted: 822 Post(s)
National bearings are not near as good as Timkin, SKF, or NSK. At least not any more. National used to be good but I believe they got bought out and quality is garbage. Although their seals are very good.
For a carrier bearing I would use Spicer.
Corey@CNCFAB is offline
post #7 of 7 Old 05-04-2013, 06:19 PM Thread Starter
I just replaced carrier bearing with National brand and it seem good quality to me. Paid $30 for it and got Precision u-joints. $13 a piece. So I got carrier bearing and 3 u-joints all total was $93 include 33mm socket. I think it wasn't that bad. Took me about several hours to do it and everything went smoothly. Test drove it and no more vibration. I was a little bit concern about the nut on the driveshaft that is 33mm socket. Said it need to be 300 ft lbs torque but I tighten it up with air impact that it rated 300 ft lbs torque. I also put just a little bit of loctite on it. So hopefully it won't come off.
DP Tuner
5" Straight Pipe
6637 DIY Intake
Riffraff CCV
05-07 Grille
2.5 Leveling Kit
LED tail lights
Billet Grille
Line of Fire
