boost help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-20-2008, 07:13 PM Thread Starter
mattypsd's Avatar
Send a message via AIM to mattypsd
boost help
i have a dp tuner and a boost fooler..
i followed directions carefully putting them on.
I see the average boost is higher then what mine gets from reading many other threads. I can get a max of about 20. I noticed in my 120 race mode my truck throws a code that comes on for a little then goes away after about ten minutes. Someone said its an over boost code but how could it be if i have the fooler on it? Anyone know what the deal is?
Thanks
mattypsd is offline
post #2 of 7 Old 02-20-2008, 07:18 PM
pwrstrokinrebel's Avatar
Send a message via AIM to pwrstrokinrebel
your boost regulator my be turned up to high.... it did it to me when i put it on my truck i turned it down and no more light..... and if you don't have your waste gate plugged you wont get much hight then 20..... to plug it just pull the red wire on the waste gate and put a screw in the whole....i have hit a max o 34 psi i have a big head waste gate so i get more psi
2000 F-250 7.3 PSD
Bully Dog 6 Position
K&N air intake
MBRP 4" Striaght pipe
triple gauge pod
ITP "Overboost" kit
Foil Delete
Train Horn
3.3K Mod
pwrstrokinrebel is offline
post #3 of 7 Old 02-20-2008, 07:19 PM
John Wood Nut Swinger
strokin_early_99's Avatar
It is an overboost code. Turn the overboost annihilator Dile #########one notch. Keep turning in one notch at a time until you can no longer set the SES light.
Read two posts down. I was telling you to turn it the wrong way in this post...I am an idiot some times.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #4 of 7 Old 02-20-2008, 07:45 PM Thread Starter
mattypsd's Avatar
i believe it is turned all the way clockwise as far as it could go
mattypsd is offline
post #5 of 7 Old 02-20-2008, 07:51 PM
Originally Posted by strokin_early_99 View Post
It is an overboost code. Turn the overboost annihilator ############# one notch. Keep turning in one notch at a time until you can no longer set the SES light.
Edit, EDIT....I am an idiot..........If you turn it clockwise it will increase the pressure allowing the MAP to read.
You have to pull out the know first and then turn it counter clockwise, out. When you pull out on the know the regulator is then adjustable.
post #6 of 7 Old 02-21-2008, 05:25 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Then its wide open, might as well not have it on there, turn it all the way counterclockwise, and then turn it up a little at a time until you hit the light again and then turn it down.
Also, an overboost light typically will go off quickly, I think your truck is setting the 1211 code.
Remember the overboost light won't come on until you have exceeded around 24-25 pounds of boost, so if your only making 20, there is another issue.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #7 of 7 Old 02-21-2008, 10:20 AM
blk99's Avatar
yeah sounds to me to be a weak HPOP....
early 99 cclb srw 4x4, auto, intake, exhaust, and a bunch of other asthetics to make it look better...
*SOLD* early 99 cc drw 2wd auto, PMT2 pcm with PHP tunes, exhaust w/ 6" tip, MSP intake, AD's, late 99 conversion, gauges, Terminator modded 17* HPOP, and some other pointless stuff like the zoodad, 6.0IC, etc etc....
499K original miles when sold...
blk99 is offline
