Light steering wheel shimmy between 70 and 80 MPH?? - Ford Powerstroke Diesel Forum
Old 02-20-2008, 06:03 PM
I sometimes get a very light shimmy in the steering wheel when I get past 70 mph and then smooths back out at about 80 mph. Can someone tell me me what the cause might be??
Old 02-20-2008, 06:08 PM
guess you have to drive faster.
seriously, it could be tires, you may need an alignment, etc.
do you have a leveling kit?
Old 02-20-2008, 10:20 PM
You might need an alignment. You could also put a steering stablizer on to help with the shimmy.
Old 02-20-2008, 10:22 PM
Send a message via AIM to 4everlearning
Alignment will not cause tire shake or shimmy. You need to get your tires ballanced or you may need to get them rotated because of cupping.
Old 02-20-2008, 10:48 PM
Most likely tire balance OR a little mud on the wheel back,throwing off balance
Old 02-21-2008, 03:06 AM
+1 for balancing tires. Also need to check for a tire seperation.
Old 02-21-2008, 07:09 PM
Ok, thanks for the heads up on tire balance, and alignment. these are pretty much new tires. I just got the truck. So Im not sure about alignment. I will take it to the tire shop
Old 02-23-2008, 03:50 AM
What and how much is a steering stabilizer?? Thanks
