Repairs/ mods to consider on 212k 2001? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-29-2013, 07:53 AM Thread Starter
I recently bought a 2001 F350 with the 7.3 and 6 speed. Current mileage is 212000 miles. The previous owner owned it for 10 years, and gave me every receipt he had for it, down to oil changes and tire rotations. It is in very good shape, but I'm sure there are some things I should be checking on or improving to make sure that it continues that way. My primary interest is in long term reliably, and better fuel mileage would be nice. I wouldn't say no to better power if it's a biproduct of one of the other mods, but I'm plenty happy with the power I have now.
I've heard people recommend checking the fuel pressure regulator and the HPOP, how important is that? anything else I should look into?
As far as mods, I was considering getting the AIS air intake, and some way of monitoring boost and EGT. I've heard that a free flowing exhaust can help as well, any truth in that? I've also heard that a better lift pump will protect the injection pump and injectors, is that worth looking into?
Anything else I should consider?
TempestV is offline
post #2 of 7 Old 04-29-2013, 08:21 AM
Quoted: 3 Post(s)
reg return, or FRx.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 7 Old 04-29-2013, 08:28 AM
For an intake Mod, go the 6637 route. Its the best bang for the buck and the filters can be purchased virtually anywhere.
Exhaust is ALWAYS a good idea on a diesel. Make sure the downpipe is large too. I've got 4" MBRP w/muffler on my '01 and love it. With the 6 spd, it was like driving a new truck - the exhaust didn't choke the engine and the engine braking effect was virtually gone. I'll be buying one for my '00 in the near future (after I do balljoints and put new tires on it - maintenance first!).
I increased MPG's about 3 MPG doing the intake and exhaust alone.
Check for oil in the valley of the engine. If there is, chances are the o-rings on the HPOP are leaking. Easy fix. www.guzzle7pt3.com or DieselOrings
There are tons of great sources for information out there, this website being a HUGE help for me all the time, especially since I own two of these behemoths.
2001 CCLB SRW 6spd - 375K and counting
2003 GMC Yukon - Her baby Hauler
1992 Acura NSX
1997 Honda Civic Hatchback - 2.4 liter, 6266 Turbo
ProOnThaSnow is offline
post #4 of 7 Old 04-29-2013, 12:08 PM
The lift pump/injection pump issue is a Dodge thing,98.5-02. From what I've heard the fuel pump on these is pretty good and fairy inexpensive to have one in a 911 box jic.
Be prepared to do more than you want.
Sent from my SPH-D710 using AutoGuide.Com Free App
2001 F350 CCSB ZF6
stickk is offline
post #5 of 7 Old 04-29-2013, 01:31 PM
Check the front end components too - Ball joints, tie rods, axle seals, hubs, etc. Its all DIY-able if you've got some tools and knowledge. I recently rebuilt the front end on my '01 and am going to here in the near future on my '00.
1992 Acura NSX
post #6 of 7 Old 06-01-2013, 02:35 AM
wingfooted's Avatar
depending whether or not you are in cold country - replace out the glow plugs, harness and while you are in there the injector o rings.
makes a big difference for cold starts/less wear and tear on the battery/starter
wingfooted is offline
post #7 of 7 Old 06-03-2013, 09:18 PM Thread Starter
I swapped in the 6637 filter (or more specifically, the Wix version of the same). I didn't have to modify anything other than to remove the factory airbox. I clamped an exhaust clamp on the 4" pipe between the filter and air intake hose, and used it as a mounting point for an aluminum bracket I made to bolt into one of the holes meant to attach the factory airbox.
The glow plugs seem to work just fine, so no worries there.
I'm very curious to know more about the reg return/FRx
As far as exhaust, would there be a big difference between an aftermarket 4" straight pipe exhaust and straight-piping the factory 3.5" exhaust?
The front end is good, I checked that before I bought it. The steering box has the smallest bit of play in it, just enough to annoy me. I've heard that it's possible to adjust the steering box for wear, but you really have to know what you are doing in order to not make it worse. Has anyone taken this on, or had someone fix this before?
TempestV is offline
