Boost Reading From PCM Accurate? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-28-2013, 07:46 PM Thread Starter
Just wondering how accurate the boost reading is from the pcm. I added an Edge Evolution programmer/gauges and stock reading was 15 psi, 80 hp program jumped it up to 18 psi and I just installed the WW2 and turbo master waste gate controller and I only got 19 psi. All testing done on same street at same location to try to be as accurate as possible. I will say that the difference from just the tune to the tune with the WW2 was noticeable. It pulled real strong and smooth after the WW2 install and getting on the go pedal at 1600 rpm in 6th, no surge, it just pulls nice. So I am just wondering how accurate the reading is. Thanks.
2001 F350 CCSB ZF6
stickk is offline
post #2 of 5 Old 04-28-2013, 09:23 PM
Did you try pulling up the PID on your EDGE for the MAP sensor? that would be the most accurate really, being that is what the PCM uses for your boost reading.
there are more people here much more knowledgeable then me, so please chime in if I am incorrect.
sounds like your map sensory could be a little off though, I get over 25lbs boost some days depending on air temp, oil temp etc.
2001 F350 7.3L.
349459KM on original motor.
Just rebuilt my 4R100.
Mods are simple....4" custom turbo back exhaust, stage 2 AFe CAI, Edge CTS Tuner, HID Lights, much more to come.
Use my rig for Work, If you need electrical, or electrical advice, don't hesitate to ask.
L0sts0ul is offline
post #3 of 5 Old 04-29-2013, 12:09 PM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
As long as the MAP sensor is in good condition, the reading will be accurate.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 5 Old 04-29-2013, 04:06 PM
Joel's Avatar
Quoted: 10 Post(s)
Yes, I have an auto meter gauge as well as edge insight and they read the same
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 5 Old 04-29-2013, 05:15 PM Thread Starter
Thanks fellas.
Sent from my SPH-D710 using AutoGuide.Com Free App
2001 F350 CCSB ZF6
stickk is offline
