Hazard lights not working - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-28-2013, 11:00 AM Thread Starter
pudil45's Avatar
Send a message via MSN to pudil45
If I push the hazard button as to turn them on, my turn signals won't work, neither will the hazards. Signals work if button is disengaged. Could it be a relay?
Sent from AutoGuide.com App
2001 F 350 DRW
7.3 Powerstroke
4 inch downpipe to 5 inch mitre cut stacks
Southbend Dynamax clutch
DP Tuner
2006 F-450 6.0
Bone stock
Whelen Justice Wecan
Aluminum 11' bed with folding sides
pudil45 is offline
post #2 of 4 Old 04-28-2013, 12:00 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
It's the switch I'd bet.
Because it points up, at the top of the column, it collects dirt and that grit prevents the contacts from closing. You can either replace it or try to clean it. I took mine apart (it was causing the turn relay to intermittently "buzz", it drove me crazy ) and cleaned it a few years ago, it's worked great since then.
It's kinda tricky to take apart (lots of plastic clips & springs) but if you're good at that kinds of stuff - go for it! As a test, maybe spray some WD into it and work it on/off a few times to see it if makes it better...
NoRalPh is offline
post #3 of 4 Old 04-28-2013, 12:06 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Fuse?
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 4 Old 04-28-2013, 01:41 PM Thread Starter
pudil45's Avatar
Thanks ill try that
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
