Xternal oil cooler - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-28-2013, 08:57 AM Thread Starter
Xternal oil cooler
Hey guys, just wondering if anyone has installed or found an external oil cooler?
Wanted to know if anyone else thought it would help the EOT significantly enough to be useful? I was thinking of using a filter relocate kit, or tap the pan and running a small pump to a cooler with an electric fan that is thermostatically controlled.
Any suggestions? Thanks
L0sts0ul is offline
post #2 of 5 Old 04-28-2013, 09:25 AM
Truck already has a good engine oil cooler. I don't think there is a real need for more cooling.
late 99' F350, Crew cab, SRW, 4guage pillar pod, combo driving/fog lights, 55w backup lights, drivers side battery isolation mod,6637 intake
coot1 is offline
post #3 of 5 Old 04-28-2013, 09:57 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Yea, that's the Answer to the nonexistent Problem
NoRalPh is offline
post #4 of 5 Old 04-28-2013, 09:28 PM Thread Starter
I don't see it as a problem, but its one of those things I wonder about, if you were to keep the EOTs down farther, would with increase the life of the motor... I Think its in the same field as coolant filtering, or water separation on a stock motor....
2001 F350 7.3L.
349459KM on original motor.
Just rebuilt my 4R100.
Mods are simple....4" custom turbo back exhaust, stage 2 AFe CAI, Edge CTS Tuner, HID Lights, much more to come.
Use my rig for Work, If you need electrical, or electrical advice, don't hesitate to ask.
L0sts0ul is offline
post #5 of 5 Old 04-29-2013, 07:44 AM
Quoted: 134 Post(s)
I'm not sure that's really true though. I mean, as long as the oil temp is kept within it's normal range, is that what causes it to break-down? If you lowered it's temp by say, 100F, does that really make a significant difference to it's shedding it's lubricity over time?
I'm not sure, but i can't imagine it would be worth the effort when the oil/water cooler is already doing it's job...
NoRalPh is offline
