The best feeling in the world - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-28-2013, 03:39 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
I've owned my E99 powerstroke for about 6 months and was always disappointed with the performance. I got smoked by a mostly stock 12 valve even. Skip to end to avoid the story..... There is useful info.
I was also getting roughly 8mpg. So I tested all the usual things. Fixed some boos leaks, no soot on the up pipes etc, and still crap mileage but my power did seem to get a bit better.
Last week I end up taking my buddies E99 out for a run and his turbo sounded so different than mine. His like a turbine at his boost, mine like you had an air line just blowing off.
On a whim I hooked up a 15 psi boost gauge borrowed from a different buddy and at WOT I was seeing 8psi. Okay there's a start I thought. Couldn't find the culprit until work last night. One of those sudden, and rare, moments of brilliance.
I found my EBPV acuator rod not connected. The EBPV has been unplugged since the previous owner. So it never fully came on to cause me to look. The butterfly could freely turn however it wanted. In my case about 1" from being fully open, causing my issues
So if you are having crap mileage, no power, and think your tranny is on it's way out because it doesn't like to hold overdrive, and your exhaust hurts people's ears under boost with a stock turbo. It may just be a free fix like that!
Excuse me while I go play with my new truck, as it feels like I just added 100hp.
schlutzer is offline
post #2 of 6 Old 04-28-2013, 05:11 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 20 Post(s)
Good deal
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 6 Old 04-28-2013, 07:37 AM
Joel's Avatar
Quoted: 10 Post(s)
One time when i took out my turbo i forgot to hook it back up.
The truck didn't have enough power to get out of its own way.
Glad you figured it out without spending a bunch of money first.
Lesson here is get gauges
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 6 Old 04-29-2013, 07:36 AM
rascal's Avatar
Deleting my EBPV this weekend. Can't wait!
Glad you solved your issue.
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #5 of 6 Old 04-29-2013, 02:02 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
nice, i made sure to check that when i didnt up-pipes.
i cant wait to do the ebpv delete with high flow outlet.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 6 Old 04-29-2013, 06:18 PM
Gunner
GunnerB's Avatar
The best ones are free ones!
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
