EGT temps? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-27-2013, 07:59 PM Thread Starter
J'sF-250's Avatar
EGT temps?
I have a 02 7.3 and my EGT temp is tapped in at the bottom of the header/exhaust manifold was wondering how hot I can get it? I have been backing off after 1,000 can I go higher then that?
Sent from AutoGuide.com App
02 F-250
4inch procomp suspension lift
35inch Nitto trail grappler MT's
Black sport grill
18 inch rims
Warn locking hubs
Gen2 RiffRaff wicked wheel
Straight pipe
6.0 Tranny cooler
Maghytech deep Tranny pan
6637 Intake mod/RiffRaff pre filter
RiffRaff inter cooler boots
CCV mod
Boost/Pyro/Trany/Volts on pillar
DP-Tuner F5- high idle, 60 tow, 80 eco
J'sF-250 is offline
post #2 of 6 Old 04-28-2013, 04:37 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
You do not want to be above 1250* for very long. Higher temperature spikes are okay, but sustained heat is what causes issues.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 6 Old 04-28-2013, 05:39 PM
Eco Taxi's Avatar
1250 is the rule of thumb I use as well
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Eco Taxi is offline
post #4 of 6 Old 04-28-2013, 05:42 PM
Same here, I try to stay below 1250 but I have been told spikes above that for short periods of time will not hurt anything.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #5 of 6 Old 05-05-2013, 06:17 PM Thread Starter
J'sF-250's Avatar
Oh ok thanks everyone... Yea seems like it will hold at 1,000 for a while and then slowly go up and I always back off but want to keep going
02 F-250
Black sport grill
18 inch rims
Warn locking hubs
Straight pipe
6.0 Tranny cooler
CCV mod
J'sF-250 is offline
post #6 of 6 Old 05-06-2013, 06:50 AM
hansel's Avatar
Quoted: 100 Post(s)
I've only had mine get as high as 1100* pulling my camper, and thats only when climbing a grade and it kick out of overdrive, then I back off some too keep those temps down.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
