boost leak???? - Ford Powerstroke Diesel Forum
Old 02-19-2008, 03:54 PM
boost leak????
ok here is a video of the noise my truck is making is it a boost leak??? or something else cause idk MySpaceTV Videos: more smokin by Eric!!
Old 02-19-2008, 03:56 PM
MySpaceTV Videos: more smokin by Eric!! sorry this is the link for the video
Old 02-19-2008, 03:58 PM
i dont know but it sounds cool, love the idle
Old 02-19-2008, 04:05 PM
I missed something, what is your problem? Sounds a little loud, but no issues I can tell.
Old 02-19-2008, 04:08 PM
the loud hissing coming from the exhaust when i step on it
Old 02-19-2008, 04:12 PM
Pull your turbo and look at the exhaust wheel... It could be damaged, causing a bit of that noise. Are you having any issues that go along with the noise?
Old 02-19-2008, 04:14 PM
yeah no power someone said that the boots could be bad but idk
Old 02-19-2008, 04:16 PM
You would not see a differance in sound out the exhaust if the boots were bad. Are your EGT's higher? Remove your intake and grab the compressor wheel. It should spin free, with little movement in and out and up and down.
I would bet something is wrong with the turbo to be getting that noise. It could also be a bad EBPV, maybe closed part way and stuck.
What setting were you on in the chip?
Old 02-19-2008, 04:17 PM
yeah there alot higher it was on the 140
Old 02-19-2008, 04:23 PM
Pull that intake off and get hold of that wheel. Also check to make sure the EBPV is not stuck closed a bit. Can you get a vid of it at idle, with the hood up, over by the turbo?
