Long crank to start time cold or warm - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-27-2013, 05:11 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
Question Long crank to start time cold or warm
I have a late 99 7.3 with 287,925 miles on it and it takes a few good seconds of cranking for it to fire up. Doesnt matter if its warm or cold but more so when cold. So i think my glow plugs are fine. When its a cold start just a small amount of white smoke but after a little bit of idling it clears up. Other than starting the engine runs strong and idles just fine. So i think my injectors are still fine. Like i said not only when cold i could be going through a fast food drive thru and when i shut the truck off to place my order, and go to start it, it doesnt fire right up it takes a few seconds. Is my hpop getting weak? What could be the deal here?
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 8 Old 04-27-2013, 06:41 PM Thread Starter
Quoted: 2 Post(s)
nobody.. damn powerstrokes lol
post #3 of 8 Old 04-27-2013, 07:03 PM
justinlogue5_0's Avatar
Before any of us can really help you we need some data info. Get you some gauges (I recommend a manual one for test purposes) and lets see what your hpo readings are while driving,wot, and while cranking. Could be several things right now.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #4 of 8 Old 04-28-2013, 02:56 PM Thread Starter
Quoted: 2 Post(s)
no thanks ill just take the truck to my local diesel repair buddy he will tell me whats wrong with it
post #5 of 8 Old 04-28-2013, 03:09 PM
Then why even bother asking for help on here? Good luck.
It never ends!
post #6 of 8 Old 04-28-2013, 04:35 PM
Justin@DP-Tuner's Avatar
Quoted: 57 Post(s)
It sounds like an IPR issue possibly. Sometimes they stick and cause the issue you are having. You can remove it and try cleaning it. Be sure to get new o-rings if you do this though.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 8 Old 04-28-2013, 05:15 PM Thread Starter
Quoted: 2 Post(s)
just ordered the ipr o-ring kit on ebay. Ill take it out shoot some brake cleaner on it, put new rings on it and see if that helps. thanks
post #8 of 8 Old 04-30-2013, 04:42 PM
AnthonyU's Avatar
Quoted: 8 Post(s)
change your picture
AnthonyU is offline
