Safe jumpstarting - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-26-2013, 07:45 PM Thread Starter
Quoted: 5 Post(s)
Safe jumpstarting
I've jump started hundreds, if not thousands of vehicles, and never had a problem. I'm a contractor, and I've used my old 96 f150 to jump start more heavy equipment than I could even begin to count- Forklifts, backhoes, dozers, skidsteers, generators, ect. However, I recently bought a 2001 F350, and yesterday, it seems that I toasted the alternator while jump starting my old F150. Since I'd rather avoid this in the future, and because with my line of work, using my work truck to jump equipment is a fact of life, I'm wondering if someone makes some sort of surge protector designed to protect the charging system on the vehicle providing the juice? I have a 300amp jumpstarter that runs on 110v that I use if I have power, but that's not always an option, and considering the size of the equipment I'm often jumping, and the fact that starting the engine from cold often requires extended cranking, a little battery powered jumpstarter pack isn't going to do the job. I always used a set of fairly light 4-6 gauge? jumper cables with my F150, but when I bought my F350, I gave my old cables to my girlfriend for her car and bought a set of 2 gauge cables (the heaviest duty cables they had at the parts store).
TempestV is offline
post #2 of 7 Old 04-26-2013, 07:48 PM
I think Your alternator was just ready to go
1992 F250 4x4 260K 7.3 IDI hypertech turbo SOLD
1997 F250 cc 4x4 now with a 96 psd, zf5 diy air filter & tw 6 pos, Dana 60 comingsoon 1995 f350 cc 295k 7.3 zf42 the doner for my 97 Donated & dismantled
slandry786 is offline
post #3 of 7 Old 04-26-2013, 08:14 PM
Joel's Avatar
Quoted: 10 Post(s)
Use this as an excuse to get a chip with a high idle tune for jump starting.
In reality, it wont make much difference. But a good excuse to get tunes
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 7 Old 04-27-2013, 06:25 AM Thread Starter
Quoted: 5 Post(s)
Would there be any advantage to getting a high output replacement alternator?
TempestV is offline
post #5 of 7 Old 04-27-2013, 12:54 PM
JSchuricht's Avatar
Yes, a higher output alternator could help with jump starting large equipment to an extent. You would still be limited by the cables.
JSchuricht is offline
post #6 of 7 Old 04-29-2013, 06:31 AM Thread Starter
Quoted: 5 Post(s)
I ended up getting the standard 110 amp alternator with a lifetime warranty. I couldn't find the high output locally, and would have had to ship it in, which wasn't going to work on my daily driver. Eventually, I intend to mount a high output alternator/ welder in the secondary alternator position, which will give me plenty high output.
TempestV is offline
post #7 of 7 Old 04-29-2013, 07:31 AM
^I was just going to suggest adding the "Ambulance package" and running two alternators.
2001 CCLB SRW 6spd - 375K and counting
2003 GMC Yukon - Her baby Hauler
1992 Acura NSX
1997 Honda Civic Hatchback - 2.4 liter, 6266 Turbo
ProOnThaSnow is offline
