Common Rail 7.3 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-18-2008, 03:29 PM Thread Starter
moore20017.3's Avatar
Common Rail 7.3
I have thought about fitting the motor with mechanical injection, the hpop gear is not in time with crank, damn.
I have got another dumb idea brewing. Why can we not machine a plug into the oil passage going from High pressure oil rail in head to injector and then use oil rails for the common rail. Then all we have to do is machine plugs that fit into the injector sleeves bored for common rail injectors. There are ports at each cylinder that are plugged, come out of those with the high pressure tubes to injectors. The VP-44 pump can be retrofitted to HPOP location.
The problem for me is electronics, I am not electrically inclined, but the old duramax uses 94 volt to fire injectors. I think ours are 110, I don't know. Is the firing sequence similar enough to use a powerstroke IDM to actuate injectors.
This may be a LONG SHOT but with common rail injection we eliminate the need for Big oil, Big injectors. Thats $6,000 we could spend on Cunninghams and a girdle.
The common rail to me is a much better set up for high horsepower. You can CRANK some horses out with simple programming and then cut it back when you don't need it.
Let me know if I am crazy or not.
GT4594 T6
238/100
537/1050
moore20017.3 is offline
post #2 of 11 Old 02-18-2008, 03:42 PM
todd's Avatar
my vote is for crazy
traded it for an 06 dodge sorry
todd is offline
post #3 of 11 Old 02-18-2008, 03:44 PM
Marine Raiders>Seals
najaf4life's Avatar
no your not crazy thinking about putting a common rail on 7.3L... because it is already in the works for a couple of guys... I have heard that someone might have a package out soon that you will be able to purchase for your 7.3L that will be common rail... but that has been awhile since I have heard that... sorry but that is all the info that i got..
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #4 of 11 Old 02-18-2008, 04:24 PM
AJF
AJF's Avatar
My vote is for doin it or gettin that pack naja4life was talkin about
AJ
2001 F-250 Lariet
Ext. Short Bed 4x4
DP Tuner, JWVB, Cowl Induction Hood, 6637 Intake,
4'' MBRP Exhaust, WW, Dfuser Fooler, Mac Inc. HPO-X, CCV mod, no EBPV, DI up pipes, Bilstein schocks, Ranchhand Bumper
AJF is offline
post #5 of 11 Old 02-18-2008, 04:43 PM
Keep those wheels turnin,mine done locked up.I count on smart people like you to come up with ideas.
-3Deez
2014 Ram Crew Cab 6.7
2001 F350 Crew Cab 7.3
3Deez is offline
post #6 of 11 Old 02-18-2008, 05:03 PM
lukecline
Guest
Posts: n/a
Quoted: Post(s)
Originally Posted by moore20017.3 View Post
Custom built 5'' aluminum stacks
Edge Evolution
Dfuser Steriod T Module
AFE Stage II
Custom Hybrid GT45 and intake manifold
Custom polished 4'' 304 SS downpipe to Aluminum
Custom traction bars
Custom weight bracket w/ IH weights
Rear locker and front spool
Dfuser TC lock up switch
Custom Air bag set up with compressor and reserve:
4'' lift
315 BFG MT's
Three pod AutoMeter guages
Are you running the gt45 with stock injectors or what?
post #7 of 11 Old 02-18-2008, 05:17 PM Thread Starter
Check out my other thread (Custom GT45 hybrid). It pretty much covers it.
Yes Stock injectors, result, lower backpressure, better top end performance, no surge, just slight turbo lag below 1500 RPM. I will be running it indefinetly.
Eventually I'll either go mechanical, stage III or common rail if I can figure out the electronics.
GT4594 T6
238/100
537/1050
post #8 of 11 Old 02-18-2008, 06:05 PM
John Wood Nut Swinger
strokin_early_99's Avatar
The HP oil rails will not handle the pressure you are talking about with a common rail. A common rail will run between 25K psi and 29K psi fuel pressure. The heads will handle 5K psi and some have had heads split with 5K psi of oil pressure from what have read.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #9 of 11 Old 02-18-2008, 06:09 PM
Cynic
Dirk's Avatar
I bet that is down right scary.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #10 of 11 Old 05-15-2008, 06:44 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
moore20017.3 Keep it up, I think your on to something. Let's us know how it goes!!!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
