6.0 tranny cooler - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-25-2013, 05:27 PM Thread Starter
goats's Avatar
Quoted: 2 Post(s)
6.0 tranny cooler
What's needed to run one
goats is offline
post #2 of 3 Old 04-25-2013, 05:35 PM
hansel's Avatar
Quoted: 99 Post(s)
The 6.0L cooler iteself, which mine came with a tranny line that wrapped it around and down the front frame on the passenger side, some 1/2" tranny line, some fittings to reduce the 1/2" down too 3/8" and about 2 or 3 hours to do the job.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 3 Old 04-25-2013, 06:32 PM
Quoted: 13 Post(s)
This is the fittings I used for my install. I had to make a trip to the pick & pull and get a cooler line nut for the tubing I have pictured as I didn't want to cut my old cooler lines. It made for a very clean install. What did you do to your 7.3 Today?
Dave
02 F350 CCLB Lariat 4x4 auto
250,000 on the clock
dieselsite trans filter coolant filter
diy ccv catch can with return line
6637 filter
Stancor GPR
6.0 tranny cooler
4" Diamond Eye K4318S-RP exhaust
riffraff regulated return
dual alt.style upper rad. hose
05-07 head light mod
PHP Hydra
Alliant Power 160 single shots
WW2
HPOP hoses and cross over hose from Corey
3 gauge A pillar gauge pod with EGT, trans temp and boost gauges. Autometer ford matched gauges.
glow plug light installed in gauge pod.
A/C mod
Banks Exhaust brake and Smart Lock
welove2drive is offline
