Common spot for oil leak? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-25-2013, 12:36 PM Thread Starter
Lunnzz's Avatar
So I have an oil leak on the passengers side of the engine that runs down to the trans. Besides the valve cover what on that side of the engine would leak oil? I plan on putting new valve cover gaskets on soon just haven't gotten to it yet.
Thanks
2001 F-250 Superduty
Edge programmer
AirRaid intake
4" open exhaust
6" lift
37x13.50x18 Toyo mud terrians
Lunnzz is offline
post #2 of 13 Old 04-25-2013, 12:43 PM
timmyboy76's Avatar
vc's are good. No need to waste money there. Look in the valley of the motor. See if theres a puddle under the fuel bowl or the turbo area. The hpop can leak or the turbo/pedestal can be the other source.
Riffraff Diesel: "Mechanics Parts Cabinet" Combo kit
Theres also a plug on the back of each head ,that could leak, but not common though...Riffraff Diesel: Oil Rail End Plug Gasket/O-ring
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 13 Old 04-25-2013, 08:24 PM Thread Starter
Lunnzz's Avatar
There is some oil in the valley would that make it down the passenger side of the engine?
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
post #4 of 13 Old 04-25-2013, 09:14 PM
Rodslinger's B1TCH
i had a drippy leak on the passenger side for a while that left a little puddle everywhere i parked. i decided one day that i was going to find that leak after i did an oil change with synthetic. i used up 5 cans of citrus degreaser on the underside of the engine and kept hosing it off until i got 10 years of gritty grease off of the underside.
it's been about 3 or 4 weeks now and there is no sign of a leak now
apparently synthetic oil is supposed to leak worse than dino....
steve604 is offline
post #5 of 13 Old 04-25-2013, 09:15 PM
Rodslinger's B1TCH
and i've read that the dipstick tube in the oil pan is a common place for leaks
steve604 is offline
post #6 of 13 Old 04-25-2013, 09:19 PM
Gunner
GunnerB's Avatar
Is it oil or dirty fuel?
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
post #7 of 13 Old 04-25-2013, 10:34 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
Yes it will. There is a weep hole in the back of the valley on the passenger side where everything drains down.
This is true as well.
Good call. Dirty fuel very closely resembles oil.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 13 Old 04-25-2013, 10:53 PM
Quoted: 865 Post(s)
Feedback Score: 3 reviews
Thanks
Does it leak on the exhaust manifold side of the passenger or the intake manifold?
If it's the exhaust manifold side then chances are the VC bolts may just be loose.
If it's in the valley you will not see it leak from the outside, it will all drain behind the bellhousing.
Also could be the O-ring on the back of the head.
Corey@CNCFAB is offline
post #9 of 13 Old 04-26-2013, 06:48 AM Thread Starter
Lunnzz's Avatar
Are you talking about the O-ring thats on the plug that is on the back of the heads? I tightened all the valve cover bolts that were easy to get to and they were tight. I did some reading last night and watched a video and mine is draining oil through that weep hole. I am going to clean all the oil out of the valley that I can get to and start the truck and check to see if I can find the leak. If I can't find the leak I am still just going to get the seal/o-ring kit from RiffRaff and some other parts and change them. Like I said before truck is about to roll over 200k and I am sure it won't hurt to change them out.
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
post #10 of 13 Old 04-26-2013, 12:09 PM
Quoted: 865 Post(s)
Thanks
Is the oil leak coming from inside the bellhousing out the flywheel inspection cover or down the outside to the starter?
And yes to the O-ring for the plug on the back of the head. Is that one leaking?
