7.3L mid range throttle lag ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-25-2013, 06:40 AM Thread Starter
TundraRat's Avatar
I have a 2001 F350 with the 7.3L in it, I have started noticing mid range throttle lag. up to 1/4 throttle is good power also 3/4 and full throttle has good power no real lag, it's just starting to get going " from a red light" under easy acceleration 2/4s throttle I notice a bad lag in power ?
Anyone seen this and if so help. thanks
TundraRat is offline
post #2 of 7 Old 04-25-2013, 07:22 AM Thread Starter
TundraRat's Avatar
May also be not shifting right in mid range, not sure seems like the motor hangs or bogs a bit then will shift later than it should..
This only happens at 2/4s throttle above or below 2/4s throttle everything runs awesome.
post #3 of 7 Old 04-25-2013, 06:19 PM Thread Starter
TundraRat's Avatar
anyone ?
post #4 of 7 Old 04-25-2013, 06:31 PM
russtwentyfour's Avatar
Maybe a going bad tps sensor
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #5 of 7 Old 04-25-2013, 06:36 PM Thread Starter
TundraRat's Avatar
I'll check that out. Thanks 4 the reply. going to get some tuner cleaner and spray the hell out of it.. would the TPS send a code ?
post #6 of 7 Old 04-25-2013, 06:50 PM
No it won't send any codes or at least it didn't on mine, I took mine off and spayed electrical parts cleaner in the crack while working with screwdriver then sprayed wd 40 and worked a little. Has been great for almost a year now. Napa sells them also but not near the quality or price of oem.
Mbrp 4" turbo back
Ww2
Afe rear end cover
post #7 of 7 Old 04-27-2013, 12:27 PM Thread Starter
TundraRat's Avatar
Found the problem, it was air in the fuel system from what I resealed the hpop. It fixed itself.
Tags
mid range , throttle lag
