Black Smoke HELP - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-23-2013, 04:55 PM Thread Starter
AnthonyU's Avatar
Quoted: 8 Post(s)
Black Smoke HELP
Hey guys a little help here I just had my turbo wheel replaced with a WW2 and also put on a CFM intake manifold. Prior to the work I had litte to no black smoke and my EGT's were low until I would really get on it. Now if I accelerate med. pedal I have alot of black smoke and EGT's are near 1000. I have a PHP tuner and other mods by the way the entire turbo was taken off and the two gaskets were replaced and no delete either.
AnthonyU is offline
post #2 of 7 Old 04-23-2013, 06:43 PM
mcyrana's Avatar
How quickly and how much boost are you making with the new impeller? maybe it was installed wrong?
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #3 of 7 Old 04-23-2013, 06:48 PM Thread Starter
AnthonyU's Avatar
Quoted: 8 Post(s)
28 lbs of boost i don't think I should have this much smoke
AnthonyU is offline
post #4 of 7 Old 04-23-2013, 07:09 PM
mcyrana's Avatar
no. not at all.
is your MAP and MAT sensors connected? tubes and all? no leaks in the intercooler pipes and is there a tuner?
mcyrana is offline
post #5 of 7 Old 04-24-2013, 12:43 AM Thread Starter
AnthonyU's Avatar
Quoted: 8 Post(s)
All tubes are connected I honestly don't know where the MAT sensor is and what is the best way to tell if you have a leak? All connection are tight I am just not sure what the deal is. Yes I do have a tuner from PHP
AnthonyU is offline
post #6 of 7 Old 04-24-2013, 04:51 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
I belive the MAT sensor is pre turbo but i could be wrong, that sensor could be intake air temp sensor.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #7 of 7 Old 04-25-2013, 03:57 AM
mcyrana's Avatar
MAT is the Manifold Absolute Temp sensor. when that thing goes bad on most powerstrokes theres alot of smoke. it senses the temp of the air coming in so the truck can fire the injectors correctly
mcyrana is offline
