Is this normal? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-23-2013, 08:48 AM Thread Starter
Is this normal?
I was looking under my truck today because every time I am turning my steering wheel all the way when making turns I hear a grinding noise.. I'm not sure what it is. Here are some pics of the front axle it seems crooked, the part where it is holding the wheel/tires in place.
j90reaper is offline
post #2 of 9 Old 04-23-2013, 08:59 AM
01Crewcab7.3's Avatar
The grinding is more than likely your tires rubbing the leaf springs at full lock.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 9 Old 04-23-2013, 09:09 AM Thread Starter
Sorry, what exactly does that mean? And how can I fix it? Does that mean my manual hubs are on lock? And does the axle look right/normal?
post #4 of 9 Old 04-23-2013, 09:41 AM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
It means your tires are too big for your wheel wells. when you turn all the way to one way or another the tire is catching the leaf springs or part of the frame. Either you going to have to get smaller tires, lift the truck or cut what catches obviously dont cut the leaf spring
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #5 of 9 Old 04-23-2013, 09:42 AM
Yes, it is normal that your hubs look like they are leaning. That's how they are built.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #6 of 9 Old 04-23-2013, 09:48 AM Thread Starter
Ohh okay thanks, and would it be a problem if I were to just leave it as is and just don't full lock the wheels when turning/reversing?
post #7 of 9 Old 04-23-2013, 10:56 AM
I have been running mine like that for the last 2.5+ years. No issues.
Tim
post #8 of 9 Old 04-23-2013, 03:22 PM Thread Starter
Ahh okay, thanks, I appreciate all the help.
post #9 of 9 Old 04-23-2013, 08:51 PM
JSchuricht's Avatar
I can't remember how the stop is setup on my SD but on my OBS it's just a bolt in the knuckle that limits the turning. I put a washer behind the bolt as a shim to prevent me forgetting how far I can turn the wheel.
JSchuricht is offline
