2000 SD f250 4x4 crew brakes - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-23-2013, 05:16 AM Thread Starter
How much does a brake job run for all 4 wheels? Thanks,
bloyd1 is offline
post #2 of 9 Old 04-23-2013, 05:31 AM
Jerrybizzle's Avatar
Quoted: 24 Post(s)
You mechanically inclined enough to do it yourself or are you talking about having it done?
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is online now
post #3 of 9 Old 04-23-2013, 05:38 AM Thread Starter
Having it done.
bloyd1 is offline
post #4 of 9 Old 04-23-2013, 07:09 AM
Quoted: 3 Post(s)
just pads or all new hardware?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 9 Old 04-23-2013, 07:11 AM Thread Starter
Replace pads, turn rotors is needed.
bloyd1 is offline
post #6 of 9 Old 04-23-2013, 09:44 AM
Don't turn rotors, buy new. If they "need turned" due to warpage then replace them since a thinner rotor will warp sooner.
Replacing pads is cheap and easy. 20$ parts per axle and almost as easy as removing the tires.
Rotors fall off also but I haven't priced them yet.
If you can't do brakes then, well, I don't know what to say.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #7 of 9 Old 04-23-2013, 09:49 AM Thread Starter
The problem is not that I can't do the work myself. I normally do. But, I'm working 6 days a week 12hrs a day and just don't have the time to do it.
bloyd1 is offline
post #8 of 9 Old 04-23-2013, 09:59 AM
Calitpers are $67, Pads run about $20 and rotors are about $40 each. 4x $70=280 + 4x$40=160 +$20 Total parts $460 atleast $500 in labor. You are looking at a $1000. I did mine in about 2 hours.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #9 of 9 Old 04-23-2013, 10:03 AM Thread Starter
Thanks for your reply. I called the local ford dealership, and they said it would cost me $300.00. Like I stated, I just don't have the time to do it. Thanks to all, Bobby
bloyd1 is offline
