Tranny oil in fuel bowl - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-22-2013, 06:17 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 306 Post(s)
Feedback Score: 3 reviews
Hopefully the title got your attention. Lol. My sisters father in law is a mech for the Airforce in OK. He said that with their diesels every so often they drain the filter bowl of their trucks and fill it full of tranny fluid and run the trucks. The reason being is that the fuel nowadays doesn't lube the injectors good and this helps them out and in some cases can revive dead injectors. What think ye?
He also recommended standamine (or something to that effect) fuel treatment.
At first, my reaction is No way! But their trucks on the flight line literally drive 15ft then they have to shut them off, then start up, 15ft, shut down,, all day long. They never get to operating temp. Granted they mainly have cummins but is this a good idea in a powerstroke?
Anyone heard of this before?
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #2 of 13 Old 04-22-2013, 07:50 AM
Quoted: 184 Post(s)
No Way! Is right
It's a Ole' Timey remedy for Injection cleaning and, today with the abundance of good additives, a ridiculous thing to do. ATF is for hydraulic systems, NOT for lubrication & burning.
BUT, he's right in that systems designed before ULSD (like ours) relied on the fuel for lubrication that, today, it's not getting.
Here's the Low Down -> http://rivrdog.typepad.com/files/cop...-version-3.pdf
NoRalPh is offline
post #3 of 13 Old 04-22-2013, 07:56 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
if you have a 7.3L you can throw 2-stroke oil in your fuel tank every few fill ups.. and for my 6.0L i use rev-x and diesel keel.. the diesel kleen every 5-10 fill ups just to keep the injectors going
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #4 of 13 Old 04-22-2013, 08:23 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 306 Post(s)
Thanks y'all! I have used diesel kleen in the past many times. I need to do another treatment soon....
Bully Dog intake
post #5 of 13 Old 04-22-2013, 05:17 PM
kingbilly68's Avatar
Quoted: 2 Post(s)
2 Questions. Does It Hurt To Run Diesel Kleen Every Fill Up? And How Much 2 Stroke Oil Are You Guys Mixing Per Tank?
[/SIGPIC]2001 F-250 ecsb 4wd auto 150,xxx miles. 6637 factory straight pipe. Amsoil bypass system. Triple Gauge Pod.
kingbilly68 is offline
post #6 of 13 Old 04-22-2013, 06:34 PM
Macon's Avatar
We had a problem using .gov "biofuel" on a base somewhere, that we were turning in trucks for starting/running problems. Base Mx found fuel lines to be clogged with paint. Like actual paint.
Running tranny fluid isn't a bad thing at all. There's some folks that burn straight tranny fluid in lieu of diesel. Nothing wrong with it.
As a matter of fact, here's an article about a dude running 90% ATF in his 7.3
Automatic Transmission Fluid Fuel - Alternative Diesel Fuel - Diesel Power Magazine
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 13 Old 04-22-2013, 06:40 PM
JD3020's Avatar
Everytime i ever change the fuel filter in my truck i fill the bowl with ATF. Something that i always have nearby in a small bottle, and the truck runs a little smoother when it first fires up. I pour some in the fuel tank as well on occasion.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #8 of 13 Old 04-22-2013, 06:50 PM
goats's Avatar
Quoted: 2 Post(s)
1 Oz of ashless two stroke oil to 1 gal of fuel.
goats is offline
post #9 of 13 Old 04-22-2013, 07:05 PM
valhalla1's Avatar
I used to drive tractor trailers, all the mechanics I knew that worked on the equipment I drove down through the years would fill the fuel filter everytime it was changed with atf, once installed they would rev the crap out of them till it was burning fuel...their reasoning was it was great for the injectors... that being said I don't think I would do it to my 6.0 based on the emmission crap I haven't deleted on it...
valhalla1 is offline
post #10 of 13 Old 04-23-2013, 03:21 AM
mxfever090's Avatar
Pull up a chair, grab some popcorn and a beer and start reading.
Running a PowerStroke on used ATF
Personally I've run up to 5 gallons of used, filtered ATF per tank of fuel.
Jason
O.T.F.D. Volunteer 19
Great White - 2003 7.3l F-250 4x4 CCSB -102,000 miles and tickin
DIY intake - 4" Straight pipe - HPX - CAT ELC - 203 t stat - billet t stat housing - coolant filter - dual alt radiator hose - 12V Air compressor - 5 gallon air tank - Air line quick connects - AIR HORNS!
Hers: 2013 VW Jetta TDI
mxfever090 is offline
