1.5" leveling kit? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-22-2013, 02:49 AM Thread Starter
1.5" leveling kit?
I have an early '99 F-250 4x4 and am wanting to level the truck. From what I understand (reading on here), if you go 2" or more, you have to get an adjustable trac-bar. Not wanting to spend alot of money, and since with an early '99, the trac-bar requires some modification, will I NEED a trac-bar with just a 1.5" leveling kit? Or can I get buy without one? This is the kit I'm referring to:
Ford Superduty 1 5" Front Lift Shackle Leveling Kit | eBay
Early '99 Supercab/Longbed 4x4 F-250
276k miles and counting...
Superchip Programmer, DIY Intake, 4" straight pipe exhaust and Transmission/EGT/Boost gauges.
JHALL is offline
post #2 of 5 Old 04-22-2013, 08:21 AM
Joel's Avatar
Quoted: 10 Post(s)
If all you want is 1.5 then go for it. But if you want 2 or 3 inches, don't compromise now or you won't be happy ever.
I just did my buddies with a 3" add a leaf and the axle alignment is better now than it was with the worn out stock springs.
If worse comes to worse you can mod the stock trackbar at home for free.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 5 Old 04-22-2013, 12:16 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
IMO Its crap....looks like what we ran as kids on our 56 chevys..you will end up changing the castor and pinion angle doing it.
Any lift will move the axle out of center..its geometry.
Just get a quality kit, 2" hangers or a 2" mini spring pack.
Mini spring packs can reuse stock length shocks, hangers need longer.
Both kits require a adj track bar to recenter your axle
CT Performance, Inc. is offline
post #4 of 5 Old 04-22-2013, 02:55 PM
I was thinking of getting the X code springs for my front end to level it up....... will I need anything extra???
Coops99SD is offline
post #5 of 5 Old 04-22-2013, 03:04 PM
Quoted: 3 Post(s)
Will get you 1.5-2", may need longer shocks and as always best to get a adj track bar.
