Maintenance Suggestions??? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-21-2013, 04:32 PM Thread Starter
Question Maintenance Suggestions???
My '02 F-250 just turned 150K and seems to be still running strong. I love my truck and I'm a bit of a backyard mechanic which is to say that I like to do my own work but I'm worried that I might be neglecting something. Since I purchased the truck at 40K miles, it hasn't had any issues. I've performed just the minimal maintenance items. Should I be doing more with this engine? I am definitely not a mechanic nor do I claim to be. Probably more like glorified lube tech. I've been wondering what else I should do?? Any thoughts? I try to do most of my work myself as $ is tight. Curious to your thoughts...
Thanks!
capt5215 is offline
post #2 of 2 Old 04-27-2013, 07:32 PM
Eco Taxi's Avatar
Coolant filter - people have made homemade or then there's this kit
http://www.dieselsite.com/1999-2003f...ionsystem.aspx
Then regularly change fluids, grease the front end
And maintenance for me kind of means smart mods / upgrades
So as for that then better exhaust - 4" exhaust turbo back
And air intake - there's the 6637 mod or ais intake
There's additional pre fuel pump filter/water separator you could add
Upgrade your trans cooler to a larger trans cooler from the 6.0
Gauges - egt, trans temp, boost - varies on preference
New fuel filter
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
