Remove a section of ex pipe - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-20-2013, 05:04 PM Thread Starter
I need to remove the section of pipe after the down pipe without damaging it so I can install the kitty and then re-install the pipe. I put a Diamond Eye 4" TB on last year and should have taken the time to put the cat on then but didn't. Ideas? Thanks.
Sent from my SPH-D710 using AutoGuide.Com Free App
2001 F350 CCSB ZF6
stickk is offline
post #2 of 4 Old 04-20-2013, 11:22 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
do you need the cat for smog or something?
otherwise leave it off.
i tried t pull the pipes apart after clamping them and it was a no go.
hopefully someone has a solution.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 4 Old 04-21-2013, 05:36 AM
patbraaap's Avatar
Good luck getting them apart once the pipe gets crimped by the clamps its almost impossible to get them apart with out damaging them. you will probably have to cut the pipe and get some female short sections. I had this problem last year when MBRP sent a pipe with the wrong bend.
E99' ECLB F250 7.3l PSD
4" MBRP Straight Pipe
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Tony Wildman 6 Pos. Chip
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
Hutch and Harpoon Mod
patbraaap is offline
post #4 of 4 Old 04-23-2013, 10:09 AM
Band clamps. Cut the section out and band clamp the cat back in.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
