Coolant bottle/ Spring Torque specs - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-20-2013, 05:53 PM Thread Starter
patbraaap's Avatar
Went to drive the truck yesterday and found a huge coolant puddle under the motor, I traced it back to the coolant bottle it looks like it was coming from around the outlet nipple on the bottom. I pulled the bottle today and i cant find anything wrong, the hose looks good, and I cant find any cracks in the bottle. I even tried pressurizing the bottle and the cap bleeds off when it gets the a certain point (i think 16psi) like it should. Im stumped, the only thing i can think of is that when its hot the plastic separates and leaks,IDK im at a loss. Any Ideas? is it possible that my cap is messed up and doesn't always work right?
Also Im replacing the front leafs on my truck with x codes, does anyone know the torque specs for the U bolts, leaf bolts, track bar, sway bar, etc? Ive done a bunch of searches and everyone has a different answer.
E99' ECLB F250 7.3l PSD
4" MBRP Straight Pipe
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Tony Wildman 6 Pos. Chip
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
Hutch and Harpoon Mod
patbraaap is offline
post #2 of 14 Old 04-20-2013, 06:03 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 249 Post(s)
Have you tried pressurizing the whole cooling system, either with a manual pressure pump and fitting or running the truck hard for a little while to get the pressure up there. The OEM cap is known to be faulty, I think they've changed the design, but Ive had good luck with the Stant cap. Is this on the 99 listed in your sig?
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 14 Old 04-20-2013, 06:07 PM Thread Starter
patbraaap's Avatar
No EGR on the 7.3 and head gaskets are extremely rare on these. Im probably going to order a new bottle and cap, see what that does. i can hardly see through my bottle because its so faded and stained.
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
post #4 of 14 Old 04-21-2013, 08:17 AM
Well if you figured it was coming out of the nipple out the bottom did it leak when your pressurized it? Sounds to me its coming from somewhere else, pressurize the whole system to make sure its not leaking from the rad hoses or water pump. I wouldn't buy a new bottle honestly and it sounds like the cap is doing it's job..the caps were the problem on the 6.0s not the 7.3.
Mission7.3 is offline
post #5 of 14 Old 04-21-2013, 03:45 PM Thread Starter
patbraaap's Avatar
The Bottle didn't seem to leak. When I first found the leak I followed it up to the highest point and that was the bottom of the bottle. Its possible that it came from somewhere else. Anyone know the best way to pressurize the whole system? I'm guessing just drive it.
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
post #6 of 14 Old 04-22-2013, 02:11 PM
Quoted: 249 Post(s)
I think you can rent cooling sytem pressurizers from autozone or somethin, failing that, i seen cheapies at harbor freight for like 70 bux
post #7 of 14 Old 04-30-2013, 04:10 PM Thread Starter
patbraaap's Avatar
Well I finally got around to borrowing the pressure tester from work, and I found the leak! Like I suspected there was a crack in the coolant bottle, it was where the two halves of the bottle are glued together. Time for a new bottle!.
I still haven't found the correct torque specs for the front springs.
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
post #8 of 14 Old 04-30-2013, 04:16 PM
Quoted: 249 Post(s)
TORQUE SPECS
conversion for nm-ft-inch pounds..click link
Torque Conversion Calculator
Tie Rod End —Inner, castellated nut....................90 Nm
Tie Rod End —Inner, Sleeve Clamp Bolts................55 Nm
Drag link to pitman arm nut.................148 ft-lb
Inner & outer tie-rod end nuts................85 ft-lb
Track bar bracket to frame.....................129 ft-lb
Track bar to track bar bracket bolt............406 ft-lb
Track bar to axle nut................................... 185 ft-lb
Radius arm to axle bolts, and bracket nut.........222 ft-lb
Pinion bearing preload..................................10-20 in-lb
Pinion nut............................................... ..220-280 ft-lb
Ring gear bolts............................................1 20-140 ft-lb
Bearing cap bolts.........................................120-135 ft-lb
Steel Diff cover bolts....................................30-40 ft-lb
Cast aluminum diff cover bolts......................... 24 ft-lb
Wheel lug nuts..........................................120-165 ft-lb
Diff filler plug.............................................1 8 ft-lb
Oil filter cap............................................... ...14 ft-lbs
Engine cover bolts............................................. 15 ft-lb
Fuel return hose.............................................. .....19 ft-lb
Fuel supply hose.............................................. .....37 ft-lb
Injector hold downs....................................24 - 26ft-lb
EGR cooler clamp.......................................53 in/lb
Turbo mounting bolts.................................... 18ft-lb
Turbo pedestal bolts....................................23 ft-lb
Turbo inlet clamp.........................................9 ft-lb
Exhaust manifold.......................................... ...45 ft-lb
Idler pulley mounting bolt..................................... 41 ft-lb
Brakes, disc, front brake caliper pin bolts (2)......................42 ft-lb
Brakes, disc, rear brake caliper pin bolts (2)......................27 ft-lb
Brakes, front disc brake caliper anchor plate bolts (2)...........166 ft-lb
Brakes, rear disc brake caliper anchor plate bolts (2)......128 ft-lb
Brakes, Caliper Bleeder Screw................................13-18 ft-lb
Crossmember Bolts............................................. ....70 Nm
Driveshaft to transfer case bolts..................................111 Nm
Flex Plate Inspection Cover......................................20 Nm
Master Cylinder Outlet Tube Fittings.........................19 ft-lb
Shock Absorber (front)......................................76 ft-lb
Shock Absorber (rear).....................................46 ft-lb
Stabilizer Bar Link Bolts.........................................85 ft-lb
Starter Mounting Bolts......................................22-28 Nm
Thermostat Housing.......................................20-30 Nm
Torque Converter Drain Plug .............................12 Nm
torque converter retaining nuts............................35 Nm
Transfer Case Bolts...........................................31 Nm
Transfer Case, fill/drain plugs...............................27 Nm
Transmission Filler tube bolt..........................10-13 Nm
transmission fluid cooler tubes to cooler bypass valve............27 Nm
Transmission mount-to-cross member nuts...........94 Nm
Transmission, Auto, Drain Plug....................25 Nm
Transmission, Auto, Pan Bolts (20)............11 ft-lb
transmission-to-engine bolts................61 Nm
Water Pump Bolts...........................18 ft-lb
Water Pump Pulley bolts (4)...............18 ft-lb
Wheel Bearing/Hub Assembly Nuts (4).........135 ft-lb
Power steering pressure hose.......................24 ft-lb
Power steering pump mounting nuts......................41 ft-lb
post #9 of 14 Old 04-30-2013, 04:23 PM
Quoted: 249 Post(s)
Ive used somethin like this before as well....
SAE Bolt Torque Specs
post #10 of 14 Old 04-30-2013, 04:52 PM Thread Starter
patbraaap's Avatar
That must be a typo LOL.
Im not seeing springs on that list, thanks though.
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
