fan clutch? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-20-2013, 03:29 AM Thread Starter
Question fan clutch?
Hi Yesterday, out of the blue, the truck while driving at speed on the interstate, started roaring. It seemed that suddenly the engine had a great load on it and was attempting to climb a large hill, none of which was the case. I noticed that rpms were about where they usually were as were temps. After thinking about it, the last time I saw this was in the 80's..and it was a fan clutch on my GM diesel. My fan clutch has so much resistance stone cold that it can barely be turned by hand... I would consider it "a ton of resistance". Is my diagnosis correct on this fan clutch? If so, is NAPA a good source of clutches?
lght1 is offline
post #2 of 4 Old 04-20-2013, 05:50 AM
Term3's Avatar
There shouldn't be a LOT of resistance turning it by hand. So time for a new one. Also, good time to swap out your fan blade for a 6.0 fan blade. It'll bolt right up and pull a lot more air when needed.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 4 Old 04-20-2013, 07:25 AM Thread Starter
Hi About the 6.0.. really? I didn't know that. Thanks
lght1 is offline
post #4 of 4 Old 04-20-2013, 02:41 PM
Term3's Avatar
Yup, straight bolt on.
Term3 is offline
