Fog lights no switch? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-19-2013, 11:22 PM Thread Starter
Lunnzz's Avatar
So my truck has the fog lights in the bumper, they seem to be wired up but I have no way of turning them on. I was thinking that maybe the switch had been swapped, but I also have the button to adjust the mirrors and it does nothing also..But hey at least my transmission is fixed for now and is working great.
2001 F-250 Superduty
Edge programmer
AirRaid intake
4" open exhaust
6" lift
37x13.50x18 Toyo mud terrians
Lunnzz is offline
post #2 of 16 Old 04-19-2013, 11:32 PM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
If the fog lights came originally on the truck, then you should just be able to pull out on the headlight switch when the headlights are turned on. That is how OEM fog lights turn on. If they are aftermarket, the switch could be anywhere...
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 16 Old 04-20-2013, 12:48 PM Thread Starter
Lunnzz's Avatar
Should there be a little symbol indicating fog light on the switch? Every other vehicle I've had there was a symbol. They look like OEM, look like all the others I've seen on Fords.
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
post #4 of 16 Old 04-20-2013, 01:27 PM
Koda22's Avatar
Quoted: 5 Post(s)
Yea just turn on ur lights and then pull the switch out...should turn them on if they are factory...don't think there's a picture for it though..
Koda22 is offline
post #5 of 16 Old 04-20-2013, 03:58 PM
Quoted: 61 Post(s)
Yes, it will light up orange when the fog lights are on. It is just to the right of the actual knob.
DP-Tuner
Like us on
Justin Bochmann
post #6 of 16 Old 04-20-2013, 06:24 PM Thread Starter
Lunnzz's Avatar
Well then I do not have the correct because the knob will not pull out nor is there a orange light at all.
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
post #7 of 16 Old 04-20-2013, 11:24 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
my knob pulls out and the truck does not have fog lights. i would crawl under the dash and look for wires or a switch.
or just follow the wiring from the bumper and see.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #8 of 16 Old 04-21-2013, 06:02 AM
Heatdr1's Avatar
I was experimenting yesterday and they will not go on with the high beams,only low beams
[/SIGPIC][/SIGPIC]Mostly Stock
blue spring upgrade
RockStar wheels
Heatdr1 is offline
post #9 of 16 Old 04-21-2013, 04:02 PM
Quoted: 61 Post(s)
This is true. However, you can modify the switch to let the fog lights stay on with high beams activated.
DP-Tuner
Like us on
Justin Bochmann
post #10 of 16 Old 04-21-2013, 05:44 PM Thread Starter
Lunnzz's Avatar
Well looks like I need to find the correct switch. Got a guy local parting out an Excursion going to see if he still has the switch.
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
