Battery or alternator? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-19-2013, 07:02 PM Thread Starter
I know, i probably look like a idiot. Haha
But heres the deal, my trucks been sitting for a week or so, went out to start it up after a tree branch decided to fall on it, real nice..and it clicks. Well alright get my car jump it, assume my batteries went dead. So i left it idle for a good 20 minutes. Drive it around town no problems, radio worked fine, lights and everything. So after probably 30 mimutes of driving and getting fuel i park it.
Went out the next morning, dead again, hook up the cables and jump it. Let it idle and it ran for another 20.
I do have one older battery in the truck. One new, i rarely drive the truck since i started my new job.
Everything ive experienced with alternators is that once its dead, its wont run long, let alone an hour on a battery that had to be jumped by a car. is dead its dead and it wont run or idle, which is leading me to replace my other battery.
Moneys been tight lately so i didnt wanna jump nd replace one thing and it not be it. My beater took a ****, 250, then the fiances car along with my truck the very next weekend, and still waitin for the bill for her car, stupid gm security ****.
Any help is greatly appreciated. Hopefully i was clear enough.
Trucks runs when jumped, but wont even turn over next morning..just odd to me.
2003 Ford F-350
7.3 Powerstroke!
8 inch BDS lift.
4 inch MBRP Exhaust
Intake
Edge Juiced w/ Attitude.
40 inch tires on 20 inch Black Moto Metals.
Preston16 is offline
post #2 of 11 Old 04-19-2013, 07:34 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Do you have a DC volt meter at home? Check between the negative battery terminal and the positive wire and see if its putting out voltage. Should be somewhere in the 13.5/14 volt range. If not, its your alternator.
Another option is fire it up, take it to auto zone, advance auto or the like and have the alt. tested there. Then you can remove the batteries and have them tested too.....
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 11 Old 04-19-2013, 08:09 PM
Macon's Avatar
Well, running it should be what he said. When not running it should be ~12V. I am in agreement with the battery though. My reasoning:
1. It clicks when you try starting it (low voltage)
2. It runs and drives just fine after a jump.
3. When you try starting again, it just clicks.
That means your alternator is working like a champ, as it runs just fine. It won't start because you're batteries aren't holding a charge. If they were holding a charge, but the alternator wasn't charging, you would notice while you're driving. Lights dim, engine runs like crud and then dies, radio turns on and off... overall not running right.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 11 Old 04-19-2013, 09:07 PM
If it were the alternator, it wouldn't run for very long after being jumped - had the alt in my '00 go out on a jobsite at 1am the other night. I charged the batteries for 4 hrs (thank god the rig had a 12v charger there) and made it to town on battery alone. I never got a warning light, or anything, but the lt just wasn't putting out the voltage when I had it tested.
That being said, I think its probably your batteries. They're not holding enough of a charge or aren't strong enough to provide enough Cold Cranking Amps to fire the truck up.
Where is your batter gauge at when its running? Should be approx 14v-ish and hold solid.
2001 CCLB SRW 6spd - 375K and counting
2003 GMC Yukon - Her baby Hauler
1992 Acura NSX
1997 Honda Civic Hatchback - 2.4 liter, 6266 Turbo
ProOnThaSnow is offline
post #5 of 11 Old 04-20-2013, 02:45 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Definitely replace the older battery, and if you can replace both then do it!
It is not good to have an old and a new battery hooked up together because the old one will not have enough juice and cause the newer one to work harder which will cause it to go bad sooner than it should.
It is always best to replace both batteries together in order to get the best life out of them.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #6 of 11 Old 04-20-2013, 04:28 AM
schlutzer's Avatar
Quoted: 18 Post(s)
X2 on the both batteries thing. Replace them both, having one old one will kill the newer on very fast.
I'm going to say your newer one is likely toast as well because the temperatures your area is seeing ( I googled it quick) your truck should start on one battery. I accidentally started mine a +5 Celius so that's around 40F on one battery the other day after a ten hour sit. Turned over slow but fired okay. Just an example but I've seen many 7.3's start on one battery with relative ease.
schlutzer is offline
post #7 of 11 Old 04-20-2013, 04:58 AM Thread Starter
Alright thanks guys! Ill plan on replacing the batterys. But im gonna try and get it down to an oreillys to have the alternator tested, completely forgot they do that
And i know i shoulda replaced both, live and learn.
Ill update when i know more on whats going on!
2003 Ford F-350
7.3 Powerstroke!
8 inch BDS lift.
4 inch MBRP Exhaust
Intake
post #8 of 11 Old 04-20-2013, 05:54 AM
Doesn't Even Care
Quoted: 69 Post(s)
My alternator went on my truck the other week and it never gave me a dash light. I got the truck to crank twice(slower than normal turnover of course) and when gee checked the alternator it was bad. Ran fine when truck was running. It was daytime but still....it wouldnt crank when I got it to Advance after I shut it off.
Sent from AutoGuide.com App
Nick
"The Mistress"
post #9 of 11 Old 04-20-2013, 06:11 AM
bigbaldbob's Avatar
My vote is the batterys. Not what you want to hear but replace both at same time. Low voltage and bad batterys can kill your FICM. $200 can turn to $600 real quick. Best of luck. Also Oriely can load test the Batt for a dead cell.
2005 F350 CC, LB, SRW, Fx4 Auto, Lariat,
Gauges, Exhaust, Studs, Egr, Powermax
bigbaldbob is offline
post #10 of 11 Old 04-20-2013, 07:42 AM
Doesn't Even Care
Quoted: 69 Post(s)
He's got a 7.3, no ficm to kill in our trucks......
Nick
"The Mistress"
