All but one power door lock quit working... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-18-2013, 08:46 PM Thread Starter
HillbillyDeluxe39's Avatar
... went to lock the door today and only the front passenger works. I did the lock motor mod a few years ago replacing the resistor in the motors. Checked fuses all good, but why would only one still work I'm completely lost.
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 9 Old 04-19-2013, 05:02 PM
Joel's Avatar
Quoted: 10 Post(s)
I don't know which mod you speak of, but both my actuators happened to quit at the same time.
I replaced with universal 12v actuators and haven't had a problem in 5 years.
Good luck.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 9 Old 04-19-2013, 05:25 PM
Quoted: 904 Post(s)
Feedback Score: 3 reviews
Good luck.
Same here. When I bought mine, only the driver door worked. In less than a week the other three went out. Mine didn't have the type where you could do the resistor mod. I bought the dorman replacements from RockAuto. That was two years ago. FWIW I was surprised many other vehicles this actuator is used in.
Corey@CNCFAB is offline
post #4 of 9 Old 04-19-2013, 08:56 PM
michaelbyoung's Avatar
I had to do the door lock mod on mine back when I had my 2000. You have to pull the actuators out do the door and take them apart, pull a little metal piece out wrap it in foil. Then you need to screw it back together. It's pretty easy, there should be a write-up somewhere.
Sent from AutoGuide.com App
2006 F-350 Lariat Crew Cab Long Bed 6.0 Diesel
Chrome Pkg All Stock 185,000 miles
B&W Turnover Gooseneck w/ 5th wheel companion
ScanguageII High idle mod On board air
2011 Jumpseat Gutted Cat Mikeymod muffler
EGR delete CCV mod EC1 coolant Zoodad mod
2000 F-250 Lariat Crew Cab Short Bed 7.3 Diesel ***STOLEN*** 11/19/2011
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
michaelbyoung is offline
post #5 of 9 Old 04-19-2013, 09:04 PM Thread Starter
This is what I did few years ago, guess Ill have to pull one back out and check it. It's just weird that three would all go out at the same time. Any part numbers on those dormans? Ill report back if I discover anything odd.
2000 F250 CCSB 4x4
post #6 of 9 Old 04-19-2013, 10:41 PM
srjd's Avatar
Quoted: 2 Post(s)
Where can you get the universal actuator I'm helping my buddy tackle this tomorrow on his 7.3
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #7 of 9 Old 04-20-2013, 08:02 AM
Joel's Avatar
Quoted: 10 Post(s)
I don't remember what exactly I even got. It may have even been dorman ones.
If they fit as many vehicles as hucorey says, I might have just remembered than as being universal
Joel is offline
post #8 of 9 Old 04-20-2013, 09:23 AM
srjd's Avatar
Quoted: 2 Post(s)
Took his door panels off and those actuators look hard to get at. Looks like lots of stuff to replace his are in bad shape lots of other broken pieces
srjd is offline
post #9 of 9 Old 05-03-2013, 08:55 PM Thread Starter
Update
...those actuators look hard to get at.
Not too bad the third time around...
Pulled em out today here is what I found. Dog must have stood on the switch or power surge... idk?
Cleaned it off with some sand paper.
Sanded the "resistor delete" and brushes.
Brought it back to life, works intermittently. Parts store wants $46.99 each, prolly get some from Rockauto as suggested.
Ill do a detailed right up and post it for you srjd and anyone else who needs it.
2000 F250 CCSB 4x4
