IAT Sensor used for outside temp gauge - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-17-2013, 06:30 PM Thread Starter
So my IAT is hanging out by the BHAF not being used. I just hooked up my new edge evolution and can read the IAT's, so I thought that if I could extend the wiring I could move the sensor to a location where I could get a more stable reading. Currently it probably reads accurate when I'm moving but once I slow down the temp rises fairly quickly due to under hood temps.
Any suggestions?
Sent from my SPH-D710 using AutoGuide.Com Free App
2001 F350 CCSB ZF6
stickk is offline
post #2 of 9 Old 04-17-2013, 07:45 PM
Joel's Avatar
Quoted: 10 Post(s)
I feel like the ECM might use the data from that sensor in some way that would make it bad to have it read so much colder all the time.
Really I have no idea though.
Bump because I'm curious now.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 9 Old 04-17-2013, 07:52 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You don't have an overhead temp display?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 9 Old 04-17-2013, 07:59 PM
Joel's Avatar
Quoted: 10 Post(s)
His truck must be an XLT like mine.... I have no idea what the temp is either
Joel is offline
post #5 of 9 Old 04-17-2013, 08:05 PM Thread Starter
Correct!
2001 F350 CCSB ZF6
stickk is offline
post #6 of 9 Old 04-17-2013, 08:56 PM
Joel's Avatar
Quoted: 10 Post(s)
Stick,
Google it and our IAT is used by the ECM to control the EBV and high idle at colder temperatures.
If you've deleted the EBPV than I would so go for it and do the mod. But if your EBPV is still intact (like mine is) I would leave the IAT sensor where it is.
Joel is offline
post #7 of 9 Old 04-17-2013, 08:59 PM
Joel's Avatar
Quoted: 10 Post(s)
Double post
Joel is offline
post #8 of 9 Old 04-18-2013, 04:50 AM
goats's Avatar
Quoted: 2 Post(s)
I was thinking of moving mine as well,cause i have a scan gauge. Living in florida means I dont have to worry about the cold
goats is offline
post #9 of 9 Old 04-23-2013, 11:19 AM
Guys, the IAT sensor is meant to measure outside air temps. In the stock configuration it is located at the air filter where lots of outside air is flowing. I have a scangauge and a ford AIS and the IAT is spot on with outside air temp as long as I'm moving.
Extend the wiring and move the sensor out front, or put in the AIS, either way, that sensor should be exposed to cold outside air most of the time.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
