Icp sensor question - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-17-2013, 10:15 AM Thread Starter
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Icp sensor question
Bear with me, on the drivers side valve cover...the icp sensor, I'm fairly sure that's the acronym..if its running and I disconnect it, it should die? Correct or no? It's all full of oil, and when I disconnect it while the rig is running there is no change in the idle at all? What's this tell a person?
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #2 of 20 Old 04-17-2013, 10:25 AM
99powerstroke62's Avatar
Quoted: 56 Post(s)
The ICP is tapped into the HPO rail.
Oil in the connector is a sign of the sensor taking a dump.
When you unplug the sensor the truck Shouldn't die. The PCM gives the IPR a default setting
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #3 of 20 Old 04-17-2013, 11:56 AM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
As stated, the ICP sensor is in the drivers side oil rail towards the front of the engine. If there is oil in the connector, replace the sensor. If you unplug the ICP sensor while the truck is running, and nothing changes at all, then your sensor is bad. If the sensor was good and functioning, you should hear a change in the idle because the PCM will bump up ICP.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 20 Old 04-17-2013, 04:21 PM
I saw this post and have to piggy back on it, sorry. I was checking my icp a couple weeks ago and with the truck running I unplugged the sensor. Well, the engine shut down. So, you're saying this shouldn't happen? Is my icp going bad? Thanks for any advice and apologies to the op!
01 F350 CCSB 4x4
Leveled
AIS
4" mbrp straight pipe
Va7.3L is offline
post #5 of 20 Old 04-17-2013, 06:09 PM
mcyrana's Avatar
Because im bored im going to write this bad boy up.
The icp sensor reads the amount of pressure the HP pump is sending to the heads and he ICP relays the message to the ECM which in return controls the IPR valve ground side circuit with a pulse width modulated signal. depending on the signal the IPR will adjust the amount of oil that is dumped from the pumps output pressure.
If your truck will not start always try to unplug the ICP first just in case the sensor is sending a biased signal. If the truck RLS and you unplug the sensor and idle quality does not change the sensor is bad at that point the ECM is using default settings to run the engine. And as stated above by Justin if you unplug it when its a good sensor it will start to RLS
If you have oil in the connector replace the sensor, the diaphragm in the sensor has failed.
What ford does may differ just a smidge on some things but this is what I was taught by International on all of their engines and systems
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #6 of 20 Old 04-18-2013, 06:11 AM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
Are you sure you're unplugging the right sensor? The ICP should not do that, but the IPR will...
NoRalPh is offline
post #7 of 20 Old 04-18-2013, 06:18 AM
The Maddawg
maddawg89's Avatar
Quoted: 290 Post(s)
What are the symptoms of the ICP going bad, besides oil in it?
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #8 of 20 Old 04-18-2013, 06:22 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
rough idle and/or bad mpg's if it went and the pcm is imputting default value. or no start
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #9 of 20 Old 04-18-2013, 06:24 AM Thread Starter
Winning DUHHH
Quoted: 8 Post(s)
Yeah, that's all confirming what I thought. I noticed it had oil all over it, decided to fire it up and see if idle changed. No change at all...just the CEL, what can I expect to notice with the new sensor? Or is it just to do with startup?
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #10 of 20 Old 04-18-2013, 07:23 AM
Yes, I'm sure its the right one. Tried it again this morning and the engine stumbled like it was gonna shut off then just kept running like it was with the sensor plugged in.
01 F350 CCSB 4x4
Leveled
AIS
Va7.3L is offline
