Old 02-11-2008, 02:40 PM
fordf250honduras fordf250honduras is offline
my f250 wont start no yellow light wait to start dont come up
my f250 year 2000 wont start the yellow light wait to starti in right side of the cluster or speedmeter dont come on i check the fuses all fuses ok the car wont start
what i need to do?
Old 02-11-2008, 04:51 PM
mschn99 mschn99 is offline
unplug the fuel heater......check the fuses again....
if its not the fuel heater odds are its a bad PCM if the wait to start light doesnt work...
Old 02-11-2008, 09:51 PM
do u have owner manual what fuse number is? i dont have the reference of the fuses? can i check the relays?
Old 02-12-2008, 08:48 AM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
Should be in the main fuse box in the engine bay drivers side #22 i believe. 30 amp fuse. If this is actually your problem. Like Marc said it could be your PCM.
Old 02-12-2008, 10:43 AM
thanks i will try check the fuse 22 if not the fuse i need check the pcm? where is the pcm located? can i try to check the injectors relays?
Old 02-12-2008, 10:49 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Your PCM is located under the dash mounted to the firewall by the e-brake lever.
