chip question how much to remove? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-15-2013, 05:48 PM Thread Starter
ive been having some trouble with my TS chip. i thought you werent supposed to remove the silver tin from the connector when you install a chip but i just got an email from thoroughbred diesel saying that the copper should be "plainly visible on both sides". is this true? how much should i remove? i would try their suggestion but i dont got $450 layin around for a whole new ECM
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #2 of 5 Old 04-15-2013, 09:09 PM
Quoted: 723 Post(s)
Try not to remove the tin. If you by chance do so eventually the copper will corrode and lose continuity. I had a an extremely terrible time installing mine. The problem with mine wasn't that it wouldn't connect but a programing error from PHP. When I put the truck in drive or reverse it would die. I checked all over for reasons why it would do what it did. Cleaned and cleaned, checked and rechecked. Finally got ahold of Bill at PHP and for some reason he gave me tunes for manual trans instead of an automatic. So all my tunes were set for TC lockup all the time.
Corey@CNCFAB is online now
post #3 of 5 Old 04-16-2013, 12:28 AM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
You should just remove all of the silicone. A little bit of copper shining through is okay, but you do not want to take too much off.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 5 Old 04-16-2013, 10:10 AM Thread Starter
thanks guys! thinkin i might give a TS chip on more shot if i can get a refund by returning this one.
2002 F250
Leveled on 35s
[SIGPIC][/SIGPIC]
Cduff is offline
post #5 of 5 Old 04-23-2013, 11:42 AM
After the brass brush and fingernail, I found the best tool was a toothpick to scrape the junk off. Your goal is to remove the silicone junk. Ideally, no silver would be removed and for every bit of silver that you remove you come closer to screwing up your computer.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
