Looking for Oil additive - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-15-2013, 04:52 PM Thread Starter
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Ok so I had the rare opprotunity to sit with an on call tech at ford, the guy that the technicians in the shop go to when they cant figure an issue out. Being a diesel nut I asked to go to the diesel side of the center, in talking to the tech about my hard start he told me to get Hot shot oil additive. does anyone know where I can buy this I have looked around a little and havnt seen it. He was telling me the little valve on the top of the injector wont move as easy to fire the injector with the thicker cold oil.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #2 of 13 Old 04-15-2013, 05:19 PM
Macon's Avatar
Locations
I know the 6.0 guys swear by Rev-X, which I'm going to try in my 7.3.
http://www.revxoil.com/wheretobuy.asp
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 13 Old 04-15-2013, 05:28 PM
05_PSD_Erik's Avatar
I was a 6.0 guy and I must say that REV-X is one heck of a product! It is expensive but I ran it through three oil changes and it made a HUGE difference in the start ups and overall 'healthy' sound of my 6.0
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #4 of 13 Old 04-15-2013, 05:55 PM
05f250harley's Avatar
I have used rev x and i dont know how much it really helped because i switched to T6 the same oil change that it was add it. The combination of t6 and revx together helped my cold start alot. Ive herd of hot shot but never used it but here is a link to there site.
Hot Shot's Secret | The Original Stiction Eliminator
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #5 of 13 Old 04-15-2013, 06:17 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Rev-X!!!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #6 of 13 Old 04-15-2013, 06:19 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i dont think rev-x helped me at all but i must say that i wasnt really having any problems either i just ran it for piece of mind.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 13 Old 04-16-2013, 06:59 AM
Hot Shots has an oil and fuel additive designed just for fords. I use both of them and works great.
honeyOUT is offline
post #8 of 13 Old 04-16-2013, 07:44 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Tractor Supply carries hot shot. Over time the poppet valve will wear like anything else. Are those the original injectors on the truck as far as you can tell?
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #9 of 13 Old 04-16-2013, 08:48 AM
rural king also has hot shots and usually carries both TSC usually only has the fuel additive but some do have the oil additive as well.
honeyOUT is offline
post #10 of 13 Old 04-16-2013, 08:54 AM
Quoted: 17 Post(s)
Good to know. The one local to me only had the oil additive but good catch.
