Going to look at my first diesel today. Thoughts - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-15-2013, 11:44 AM Thread Starter
I'm going to look at a 2002 F250 lariat 7.3l with 150k miles. His craigslist ad says it has upgraded exhaust and air intake, new tires, alternator, batteries and a recent oil change. He says the trucks in great shape, but theres a small oil leak from the HPOP.
Is that leak a big deal should I avoid the truck
Thanks guys
ID:	97418   Click image for larger version
ID:	97426   Click image for larger version
ID:	97434   Click image for larger version
ID:	97442   Click image for larger version
jeckel7234 is offline
post #2 of 8 Old 04-15-2013, 11:50 AM
Justin@DP-Tuner's Avatar
Quoted: 50 Post(s)
A leak from the HPOP is not a reason to avoid the truck. That is a fairly easy fix, and a new HPOP is only about $450 if you had to buy a new one, worst case scenario.
Excessive blow-by and other major issues are a reason to avoid a truck(unless they are extremely cheap), but not a leaking HPOP.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 8 Old 04-15-2013, 01:29 PM
Macon's Avatar
^^ What he said. My HPOP has been leaking for months now. I bought an o-ring kit, but haven't bothered to use it yet.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 8 Old 04-15-2013, 03:54 PM Thread Starter
good deal thanks fellas
post #5 of 8 Old 04-15-2013, 04:54 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Check for blow by, Check the transmission dip stick & smell it, if it smells burnt, thats not a good sign, Ask what his oil change intervals where. Brakes, Un even tire wear, Cracked glass... ETC!
Good Luck!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #6 of 8 Old 04-15-2013, 06:44 PM
timmyboy76's Avatar
run the truck for a bit, then check fluid coolant level. Sure weird for the coolant level to be that low or else he's vacuuming out oil/fuel to cover it up.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 8 Old 04-15-2013, 06:50 PM
nolimit's Avatar
Good Luck!
Tom
2000 F250 Extended Cab
7.3 Diesel
200cc Injectors
38r Ball Bearing Turbo
Regulated Fuel Return
"Project Under Construction"
nolimit is offline
post #8 of 8 Old 04-15-2013, 11:46 PM
444 ci's Avatar
check oil pan for rust.
444 ci is offline
