Old 02-10-2008, 09:47 AM
Tronsb21 Tronsb21 is offline
CRUISE CONTROL HELP
2003 F-250. Cruise stopped working but there is power to steering wheel. VSS is replaced, fuses are good and connections are all good. Anyone have any suggestions as to the problem. Maybe a relay?
Old 02-10-2008, 09:52 AM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Im not exactly sure if the cruise is vacuum operated on the powerstroke or not Im sure someone will chime in with an answer. Welcome to powerstroke.org
Old 02-10-2008, 09:53 AM
todd todd is offline
there is a switch with a plug with 2 wires in it connected to it on your hydroboost unit right below your brake fluid resivor the purpose of that switch is to cancel your cruise when you hit your brakes it can be bad or the plug could have come unhooked
Old 02-10-2008, 09:58 AM
mschn99 mschn99 is offline
definately check this...
Also....just cause your getting power to the steering wheel doesnt mean it isnt a clockspring problem. All it takes is one of the wires to break.....
Old 02-10-2008, 10:20 AM
does the clockspring also return the steering to straight because i have had a slight steering problem. When driving, hitting bumps pushes the truck left or right. The steering does not return to straight. I have to return it to straight.
Old 02-10-2008, 10:22 AM
no....the clockspring is just coiled wires in a plastic shield behind the steering wheel....all it does is allow electrical currents to flow to the other side of the steering wheel and still have the steering wheel able to turn....
does your horn work??
Old 02-10-2008, 10:33 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
sounds dumb but does affect if cruise works , make sure brake lights work,if they arent then pcm doesnt know to turn it on
Old 02-10-2008, 11:48 AM
Horn works and brake lights work too. I have not noticed any electrical problems with the truck.
Old 02-10-2008, 12:53 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
Might be time to have it put on a scanner, with my predator programmer I think I can see when the cruise is on or off and see if the steering wheel buttons are working. It should be totally electronic and there are several switches and light bulbs that have to be happy for it to work.
Old 07-05-2008, 05:18 AM
inkedinmiami inkedinmiami is offline
Quick and dirty test. You can unplug wires from the hydroboost unit install a jumper wire from one side of the plug to another. Drive and try the cruse control. If it works it's the sensor or the hydroboost unit.
The stearing sound like its in the stearing gearbox.
