How much - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-14-2013, 05:48 PM Thread Starter
Redlazer's Avatar
How much
What is the Normal amount of boost and egt that people are seeing?
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 7 Old 04-14-2013, 05:56 PM
Zaairman's Avatar
Quoted: 12 Post(s)
You need to get a whole lot more specific... WOT? Highway? Towing? What?
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 7 Old 04-14-2013, 05:57 PM
Macon's Avatar
You'll get 500 different answers for 30 different trucks. I get 24# boost at WOT, 5# freeway cruising, 1-2# city cruising, 10# normal accel, 3-4# light accel. EGT's go up with the higher boost scenarios, but I cruise on the freeway at ~550-630*
What problem are you trying to figure out? Just wanting to know if you're in normal ranges?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 7 Old 04-14-2013, 08:15 PM
Joel's Avatar
Quoted: 10 Post(s)
Dude, you have an awesome memory!
My EGT on the hwy is a little higher on average, but my truck is heavy so that makes sence.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 7 Old 04-14-2013, 08:39 PM
Macon's Avatar
Just things I pay attention to. Historical data aids in fixing issues before you're stuck on the side of the road. I'm on smaller tires than you as well, so a little less drag there.
But yeah, each truck will be different, which is why anything below 1250* is considered okay, and short duration spikes up to 1400* won't kill it. Other numbers are irrelevant because simply removing the muffler changes normal EGT's. Add on all the rest of the mods us clowns do, and EGT is just a cool thing to look at. Keep it below max and you won't weld a piston to the wall.
2002 F250 CCSB 4x4
Macon is offline
post #6 of 7 Old 04-14-2013, 09:15 PM
mcyrana's Avatar
my truck at WOT is pushing 26 with wastegate and 34 without
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #7 of 7 Old 04-15-2013, 10:17 AM Thread Starter
Redlazer's Avatar
I was just looking for numbers bc I just installed my gauges wanted to know around about where it should be.
CAROLINA GRAY BOY
Redlazer is offline
